Results 1 to 7 of 7
    ROG Enthusiast Array Ke1vin PC Specs
    Ke1vin PC Specs
    MotherboardASUS Maximus VI Extreme
    ProcessorIntel 4790k
    Memory (part number)32Gb
    Graphics Card #1Nvidia Geforce 770
    MonitorAOC 27" 2752
    Storage #1Samsung 850 EVO 500Gb
    CPU CoolerCorsair H100i GTX Liquid Cooler
    CaseNXZT Phantom ATX
    Power SupplyCorsair RM 850
    Keyboard Logitech 105G and G13
    Headset Binatone
    Ke1vin's Avatar
    Aug 2015
    33
    Maximus VI Extreme - i7 4790k - Corsair H100i cooler: What is normal temps
    Can anybody point me to a link that might give me some clues as to the normal temperature ranges for my rig?
    Normally the ROG Panel shows around 45C, while downloading Star Citizen Patch I saw it climb to about 64C.
    I am not doing any OCing yet. And I have not tried playing Star Citizen yet as I am concerned at to what to expect temp-wise.
    I am using the Nxzt Phantom case with 5 fans in addition to the H100i liquid cooler.
    I know my GeForce GTX 770 is designed to operate at 80C - which it does fairly quickly when jumping into Star Citizen.
    Thanks for taking time to read and any responses,
    Ke1vin
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    498
    13,531
    Normal idle voltage should be 0.7xx to 0.9xx volts and temps at idle should be about 30 degrees if you have pretty normal ambient...
    Load depends a bit on what voltage the CPU uses but say 60 degrees would be normal...70 a cpu that likes voltage...on a stress test..
    is the pump working OK on the H100...if you feel the tubes entering/exiting the cpu block does one of them feel warm?
    Ke1vin PC Specs
    MonitorAOC 27" 2752
    Headset Binatone
    Ke1vin's Avatar
    Aug 2015
    33
    Arne Saknussemm,
    I can't really tell about the hoses as the H100i GTX has a rather thick cloth braid around it.
    With this forum open to write this
    When I open the Corsair Link, the ROG LCD shows 44C
    The Corsair Link reports:
    IntelCore i7-4790K Temp 51.5
    H100iGTX Cooler Temp 29.4C
    ASUSTek Motherboard CPU Temp 44C ( matches ROG LCD )
    H100iGTX Cooler Pump 2550
    H100iGTX Fan 1560
    ASUSTek Motherboard TZ00 Temp 27.8C
    ASUSTek Motherboard Mainboard Temp 30C
    Apr 2012
    498
    13,531
    Hmmm pretty much useless info to me I'm afraid...maybe someone else can help who has tried that software?
    I just trust Realtemp or Coretemp or Aida64 for my temperatures....want to know CPU core temps...the rest is a bit meaningless I'm afraid. "CPU temp" and "package temp" and all that kind of thing can be 10 degrees lower than reality...other measurements off.
    If you have more than one monitoring program open or installed like HW monitor or AI Suite they can interfere so much no reading is reliable....Corsair link and AI suite are terrible for wanting to be the only program installed and then give all sorts of info except what you want...
    Ke1vin PC Specs
    MonitorAOC 27" 2752
    Headset Binatone
    Ke1vin's Avatar
    Aug 2015
    33
    Okay, a tech at Corsair told me that he would expect the temp to stay down in the low 40's upper 30's.
    Under stress he suggested that 60's low 70's.
    He said to try a graphic intense game and watch to see if temp spikes very fast. Mine does, to which he suggested that the cooler may not be sitting completely level on top of CPU.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hello Ke1vin
    At stock/default settings your 4790k is getting overvolted some, it's probably running 1.25v - 1.30v at stock.
    Set the cpu core voltage to 1.20v and test for stability, if it passes lower it to 1.19v and test again. Keep lowering the cpu core voltage .01v and testing until you get a BSOD or freeze then raise it back up .01v.
    The lower you can get the voltage the lower your temps will be. When you start overclocking you should be able to do 4.9GHz-5.0GHz with the H100i GTX.
    I'm with Arne on the cpu temp monitoring program, I use Realtemp 3.70. Stress testing temps can hit 90c and is still ok but I don't like to let it there very long, if your gaming temps are 75c or below you are fine.
  7. #7
    Apr 2012
    498
    13,531
    Looks like you will have to take the H100i off and remount it....check you have backplate the right way round etc and carefully hand tighten it evenly all the way down onto the CPU....half turn alternating diagonal corners....
    When you take it off have a good look at the pattern in the thermal paste....ideally it should be pretty much see-through and even all over contact surface on CPU
