ROG Front Base problems
Poacher
Hello. I installed my new ROG front base, and I've had many many problems. First of all, the colour is not as I expected, it's very very pale. It doesn't look at all like all the pictures I've seen online. Has anyone encountered this issue? Should I give it back? Here's a picture:
51644
Anyway, that's not the real issue. I looked for answers in many forums and tried many things, but I still have the same problems. After properly installing the Front Base in my computer, I proceeded to try to configure it with it's drivers and firmware, following what was said in the manual I received. I have a motherboard Maximus VII Hero installed, and my Front Base has a V44 sticker, I installed the latest drivers and also the latest firmware (V47, the only one available), and I think this is where the problems started.
When I first plugged it in, the EQ bar was on the screen, but after installing the drivers it disappeared. The EDIT function doesn't make it appear, this function only works to control the fans.
The GHz displayed on the Front Panel don't always relate to the real GHz shown by other programs (I use CPU-Z) It takes a lot of time for the base to show the same values as the software.
After some time, my computer showed me a BSOD, here it is:
51645
Every time I tried to turn on the PC again, the same screen showed. Only after disconnecting all the cables of the Front Base I was able to turn the PC on again. And I haven't tried to plug it in again, I don't want to screw things up. I can't upload the dump files now, I'll upload them later if necessary.
My BIOS is V. 2401, I've read that updating it may be a solution, but my computer is new and I've installed it a few months ago so I'm not sure of doing this, it scares me, to be honest.
Do you think that if I install an older version of the firmware I can fix this? I've seen this version is really really new, and maybe it's not optimized or something like that. Could anyone send me the V44 firmware? I can't find it anywhere, the only one is the V47. Any other solution is welcomed.
Thanks!
gupsterg
Only suggestion comes to my mind is try the latest motherboard bios when using the latest FrontBase firmware.
Intel Defector :eek: AMD Rebel
R9 5900X - Custom WC - ASUS Crosshair VII Hero WiFi - Ballistix Sport LT 2x16GB 3800MHz C16 - RX 6800 XT - WD SN770 2TB - 2x 870 EVO 4TB
24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
:eek: CPU Validation 5.198GHz@1.314v with 4.4GHz cache + RAM 2400MHz@1T :eek:
Da Music video
