Results 1 to 4 of 4
    New ROGer Array
    May 2015
    1
    G75VW - Fan Noise
    Hello, Just recently my left fan started making an incredible amount of noise constantly. This noise used to occur only briefly when booting up the computer but now it constantly is running full speed. I have cleaned both fans so dust does not seem to be the issue. The sound only occurs at higher RPMs as when I lightly blow to rotate the fan it makes a light mmmm just as the other fan but when a higher RPM is reached the loud sound occurs. If the fan is dying then where would I go about purchasing a replacement fan as I have seen various videos linked on these forums about disassembly/replacement/cleaning and it doesn't look like something out of my ability.
    Here is an audio recording of the fan:
    https://clyp.it/rebmxxvo
    Thank you for your time
    ROG Member Array
    Nov 2013
    9
    hello. there are two ways - or you buy a new fan, or take the old one off and put a drop or two of machine oil inside the fan's rotor (you'll have to take thin net off, to get to the small cup in the center, under which middle of that rotor is).
    New ROGer Array
    May 2018
    1
    GPU Fan grinding
    I know this thread is older, and I hope I can get a response. Are you saying to access it from opening the case, or can it be accessed from the bottom panel? I'd love to find an easy solution for this. When I look at the GPU fan from the bottom panel, it can be turned by hand, but it doesn't freely spin like the other fan does. It's causing my screen to randomly go into this multi-colored striation, and sometimes fade out to white completely, to which I either have to close the lid and wait for up to 10 minutes, or I have to hard restart. Sometimes when it happens I can tap or press on the keyboard, just above or around the 10-key pad and the screen will come back. Will this oil fix work for me, or is it sounding like either the GPU fan or entire GPU has to be replaced?
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,126
    Quote Originally Posted by Wiccancowboy2000 View Post
    You can probably find a fan on eBay and here is the disassembly video the best one I've seen
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
