Results 1 to 3 of 3
    ROG Enthusiast Array mikejustis PC Specs
    mikejustis PC Specs
    MotherboardRIVE
    Sep 2012
    62
    Checking File system on C: issue
    I had to do a fresh install after missing the Windows 10 rollback date and now 90% of the time I get the errors below. The first pic is the heath of the ssd. The second is the black screen of death message and the third is what happens after the 7 second countdown. The computer boots up after going through this or if I hit the any key before it counts down....Any ideas? Click image for larger version.
ID:	51712Click image for larger version.
ID:	51710Click image for larger version.
    Cosmos Ultra II
    Asus RIVE
    Intel Core i7 3930K
    Thermalright True Black Ultra 120 Extreme Edition
    G.SKILL RipjawsZ 16GB F3-17000CL9Q-16GBZH
    GTX 970SC
    EVGA SuperNOVA 1200 P2 psu
    Samsung 850 PRO 256gb Boot
    Crucial M4 128gb Programs
    Windows 10 Home 64 Bit
    BIOS 4206
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Sporadic failure might be intermittent electrical contact, I would check all cables and connectors (as in check continuity with a DMM). Also reinstall/repair (and update) the Magician software and the operating system - the Magician software might be wrong while interruptions and crashes in Windows can indicate that critical OS files or data are corrupted. You can download any number of S.M.A.R.T. diagnostic tools or stress-test benchmarking tools to drive your drive hard, an easy way to determine if it is truly failing.
    ROG Member Array THAPHAT PC Specs
    THAPHAT PC Specs
    MotherboardASUS RAMPAGE IV EXTREME
    ProcessorIntel Core i7 3960X SR0KF
    Memory (part number)GSkill 16GB (4GBx4) DDR3
    Graphics Card #1ASUS FURY X
    MonitorSAMSUNG UD590
    Storage #1SAMSUNG SSD 850PRO 1TB
    CPU CoolerCorsair H100i GTX
    CaseCooler Master HAF912
    Power SupplyCorsair AX750
    Keyboard Logitech K260
    Mouse Logitect M210
    Headset/Speakers Creative 2.1
    OS Windows 10 x64 PRO Build 11082
    Accessory #1 Logitect F-510
    Sep 2015
    21
    Try Windows Restore first.
