[Help] G751JT - Compatible memory?
Zapmi
Got an G751JT, 8GB RAM. I'd like an upgrade, but i am not sure what memory is compatible, and what to choose.
I've found these two, and if these can be used, what should i choose? The crusial is slightly more expensive than the HyperX, but nothing that matters..
Crucial DDR3L SO-DIMM 1600MHz 16GB KIT
2 x 8GB, 1600Mhz (PC3-12800), CL11, 204pin, 1.35V/1.5V
HyperX Impact So-dimm DDR3L 1600MHz 16GB
16GB 1600MHz DDR3L CL9 SODIMM (Kit of 2) 1.35V HyperX Impact Black
