Results 1 to 5 of 5
    ROG Member Array
    Sep 2015
    8
    Color Banding on G751JY - Common Issue?
    I know that these laptop panels are not made for professional purposes though I am still wondering if color banding is normal with that product.
    Does any G751 Owner see color banding in the mid-dark and dark tones on this image? http://www.drycreekphoto.com/Learn/C...r_gradient.htm
    ROG Guru: Orange Belt Array
    Mar 2015
    310
    Yeah, I can see one visible line on both images.
    Dec 2013
    492
    I only get like 1 small line in the left part of the first image and another one, about the same size, in the right part of the second image. But they are barely noticeable. And I'm not surprised because the guys from NotebookCheck have said that the display doesn't have the best gamma but it does reach quite good values of 2.5 which is pretty good.
    PS: I am using the SPlendid calibration profile but without the splendid software. Check around the forums and maybe that will make it better.
    ROG Guru: Yellow Belt Array
    Jan 2015
    129
    getting same 2 lines ^
    ROG Enthusiast Array rcarlos243 PC Specs
    rcarlos243 PC Specs
    Laptop (Model)Asus G751JT
    MotherboardGigabyte X99 SOC-FORCE
    ProcessorIntel Core i7 5820k @4.5Ghz 1.28vcore
    Memory (part number)16GB DDR4 2666 CL13 Quad Channel
    Graphics Card #1R9 290 4GB @1150 core w/ Corsair H105 + 2x Gentle Typhoon AP15
    Sound CardFiiO E17 USB AMP/DAC
    MonitorBenQ XL2420z 1080p 144Hz
    Storage #1256GB Samsung SM951 NVMe M.2
    Storage #2960GB Crucial M500
    CPU CoolerEK Supremacy Evo, 360mm HWLabs Black Ice GTX, 360mm Swiftech MCRX20-QP, Swiftech MCP655, 6x AP15's
    CasePhanteks Enthoo Pro
    Power SupplySeasonic SS-600XP2 80 Plus Platinum
    Keyboard Logitech G710+ Cherry MX Brown
    Mouse Logitech G502
    Headset Philips Fidelio X2
    Mouse Pad Razr HardMatt
    OS Windows 10
    Network RouterNetgear Nighthawk X6 R8000
    May 2014
    8
    41
    What do you expecte for a panel that is only rated 6 bit 262k?
