09-28-2015 03:05 AM - last edited on 03-06-2024 01:55 AM by ROGBot
09-28-2015 03:53 AM
09-28-2015 04:22 AM
joshindaphils wrote:
The description seams to imply this is a SATA only solution.... how sure are you that this will actually work? Additionally if it did work, I don't see what benefit there would be to using this over stock mounting.. the adapter still protrudes into the drive bay and you still have to place the drive.
09-28-2015 04:00 PM
FalloutBoy wrote:
This is not the best example as it's got a big box to stick the M.2 into but I though this might be another possibility to install a 2nd
SSD in the first bay and keep them from heating each other up. If the new SSD is short enough this might fit in at the end esp if you
remove the 2nd SSD's casing.
Deleted first URL for some reason grabbed a sata extender duh but this one is right.
M2-M2280-FLEX
http://www.adexelec.com/m2.htm
I am looking for a better example with - with a bit of luck a slightly longer cable.
