Results 1 to 5 of 5
    ROG Member Array
    Dec 2011
    12
    Rampage IV Extreme, Sound in Win10
    Hey guys, I've been trying to get the onboard sound to work in Windows 10 for a while now. I have tried all the drivers from here for windows 8.1 and Windows 10, I tried the latest drivers at realteks website, and I've tried to change the driver to High Definition Audio Device under device manager. So far, nothing is working. I get absolutely no sound unless I turn the volume to max, even at volume level 99 i still get nothing, but when I turn it to 100 I actually get sound but I get nothing that's even close to correct. The sound is very robotic and static. I would appreciate any help that could be provided on this issue.
    Forgot to mention, my sound worked flawlessly on Windows 8.1, but hasn't worked correctly since the update to Windows 10.
    ROG Guru: Orange Belt Array Snakeyes's Avatar
    Dec 2012
    42
    276
    Sorry to hear about your issue. With the same motherboard I have also converted to Windows 10. I also tried both an upgrade install from Windows 7 and a fresh install into Windows 10. In the fresh install I hand-picked drivers based on manufacturer recommendations while, in the upgrade install, I let Windows 10 choose the drivers. I used identical SSD drives for each install set up so that I could switch from one to another. To my surprise, the upgrade install where Windows 10 chose the drivers has been working great. On the other hand in the fresh install, where I forced the drivers, I have been having problems including audio.
    I am attaching my device manager driver window for audio, that has been working absolutely fine on my system. I'm not sure if it helps, but nothing ventured nothing gained.Click image for larger version.
    NAME THE SANDWICH: – White Bread, Lots of Baloney, Russian dressing and served with a small pickle.?
    Intel Core i7 8700K @5.1 Stable Delidded
    Asus Maximus X Code
    16 GB
    G skill TridentZ DDR4 ​4266 (PC4 34100)
    Corsair HX1000i digital
    EVGA 1070 GTX TiSuperclocked+
    Samsung NVMe SSD 960 pro M. 2
    Samsung 860 Pro
    Watercooled with EK block radiator fans etc.
    ROG Member Array THAPHAT PC Specs
    THAPHAT PC Specs
    MotherboardASUS RAMPAGE IV EXTREME
    ProcessorIntel Core i7 3960X SR0KF
    Memory (part number)GSkill 16GB (4GBx4) DDR3
    Graphics Card #1ASUS FURY X
    MonitorSAMSUNG UD590
    Storage #1SAMSUNG SSD 850PRO 1TB
    CPU CoolerCorsair H100i GTX
    CaseCooler Master HAF912
    Power SupplyCorsair AX750
    Keyboard Logitech K260
    Mouse Logitect M210
    Headset/Speakers Creative 2.1
    OS Windows 10 x64 PRO Build 11082
    Accessory #1 Logitect F-510
    Sep 2015
    21
    Please try again. I've installed without problem.
    New ROGer Array virusman61 PC Specs
    virusman61 PC Specs
    MotherboardASUS Rampage IV Extreme X79 Motherboard - ATX
    ProcessorIntel® Core™ i7-3820 Processor (10M Cache, up to 3.80 GHz)
    Memory (part number)Corsair Vengeance CMZ16GX3M4A2133C9R 16GB Memory Module Kit - DDR3, 2 x 4GB, 2133MHz, CL9, DIMM, XMP
    Graphics Card #1EVGA 04G-P4-3687-KR GeForce GTX 680 FTW+ w/Backplate 4GB
    MonitorPhilips 242G5DJEB 144hz, 1ms Extreme Performance 24-Inch Professional Gaming Monitor
    Storage #1SAMSUNG 830 Series 2.5-Inch 128GB SATA III
    Storage #2Seagate 4TB Internal Desktop Hard Drive - 3.5" Form Factor, SATA III 6 Gbp/s, 64 MB Cache
    CPU CoolerThermaltake WATER2.0 Pro Closed-Loop All In One Liquid CPU Cooler Dual 120mm PWM Fans 120x49mm Radia
    CaseCM Storm Trooper - Gaming Full Tower Computer Case
    Power SupplyCooler Master Silent Pro Gold - 1200W Power Supply with 80 PLUS
    Keyboard Logitech G910 Orion Spark USB Mechanical Gaming Keyboard
    Mouse Razer Mamba 2012
    Headset Logitech G34 7.1 Surround sound
    Mouse Pad Steelseries QCK+
    Headset/Speakers 5.1 Surround sound system
    OS Windows 10 PRO X64
    Network RouterNighthawk X6 Tri-Band WiFi Router AC3200
    Accessory #1 Asus 802.11ac Dual-band Wireless-AC1750 PCI-E Adapter - 1300Mbps, 2.4GHz/5.1-5.8GHz
    Sep 2015
    1
    Yeah the Realtek drivers are not working for me. I kept the driver Windows 10 installed after a fresh OS intall and it's working fine with me, it even solved my 5.1 sound issues and all my speakers are working fine now.
    Dec 2011
    24
    293
    Have Win7 w/SP1, Win8.1 upgraded to 10 and Win10 Insider Preview as multiboot - all 64bit - running RealTek 6.0.1.7623 with no problems - downloaded at StationDrivers.
    Lian-Li PC-A77F Full Tower case
    PC Power & Cooling Turbo-Cool 1200 ATX12V & EPS12V PSU
    ASUS Rampage IV Extreme LGA 2011 X79
    Intel Core i7-3960X 3.31 LGA 2011 CPU
    Intel RTS2011LC Liquid Cooling Solution
    Kingston KHX24C11T3K4/32X (quad 32Gb memory kit) 2 each
    ASUS Radeon HD7970 DirectCUII 3Gb GDDR5 PCIe 3.0 x16 Video Card (two in CrossfireX Mode)
    Western Digital Cavier Black 2Tb SATA III 6.0GB/S
    OCZ Technologies Vertex 4 SATAIII 6Gb/s 512Gb SSD
