Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    Nov 2013
    9
    G75VW power boost on USB win10
    hello, everyone
    i just upgraded to win10 on my asus g75vw. everything seems to be working fine, exept there is no possibilitie to charge my ipad using one of USB ports. does anyone know if it's fixable by now?
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    74
    2,416
    not sure if this will work or not , on the driver page there is A W7 charger plus u could install and try it u can always uninstall it if it does not work
    http://support.asus.com/Download.asp...75VW&p=3&s=388
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Yes if you find a working driver it only adds the extra power to the front right USB 3.0 port
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Member Array
    Nov 2013
    9
    thank you. i installed this driver but it doesn't seem to be working. no additional power appeared on any of the ports...
    toronto699 PC Specs
    Processori7-4770K
    Storage #1118 GB/OS
    Storage #22.72 TB
    CaseG30AB
    OS W 10
    Aug 2014
    74
    2,416
    I sent u a PM about USB boost , uninstall that W7 driver and try my PM file
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Also if the power boost is installed you should have a Notification in that bar where you can turn it on or off? I can't comment on custom drivers that is beyond my expertise's.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
  7. #7
    toronto699 PC Specs
    Processori7-4770K
    Storage #1118 GB/OS
    Storage #22.72 TB
    CaseG30AB
    OS W 10
    Aug 2014
    74
    2,416
    Clintlgm , I have a working USB boost asus file for my G751 , W8.1 version , don't see why it should not work on his G75VW as u well know asus does not update software or drivers for older laptops , pc and motherboards but newer drivers sometime work from other driver pages , that's what I do or at least try.. lol
    I love LA ,haha
  8. #8
    ROG Member Array
    Nov 2013
    9
    so you mean there won't be any drivers update for g75vw?
  9. #9
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    toronto699, Yes I agree, I've been seeing some Mod files flying around and I don't recommend them to anyone, since most of the people that come in here are not very techy to deal with things that don't work as expected.
    RosGar No I don't believe Asus will post any Win 10 drivers for the G75, or 55 were operating obsolete equipment as far as Asus is concerned.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
  10. #10
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    If you read through these threads you'll find the work around drivers to make your G75 more or less work on win 10
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
