09-29-2015 07:42 AM - last edited on 03-06-2024 01:55 AM by ROGBot
09-29-2015 08:17 AM
09-29-2015 08:23 AM
joshindaphils wrote:
All cards are different in how much they can overclock. You can void your warranty and use a modified VBIOS to increase the voltage, the increase voltage generates more heat, but allows you to clock the card higher w/o artifacts.
IMO it is not worth the possibility of voiding your warranty using a custom VBIOS and having something go wrong; that is a very expensive paperweight. If you have money like that to throw around you should buy for the performance you wanted in the first place. Again just my opinion / view on the matter.
09-29-2015 08:22 AM
09-29-2015 12:15 PM
09-29-2015 12:44 PM
Nader wrote:
Well I did flash a custom vbios But I have the original vbios for back up any time I want.
Tried flashing between both and works fine. When I flash the original vbios it reverts back to the original limitation.
09-29-2015 10:40 PM
