Results 1 to 3 of 3
    ROG Enthusiast Array
    Aug 2015
    30
    Is there a way to save power to run longer in battery G751JT?
    Is there any quick way to use less of the laptop to save power ? I need it when I do official works on battery. things that a duel core with no gpu can handle.
    Is there an option to disable the 970m and use processor gpu as needed quickly.and may be an option to turn off 2 cores
    ROG Guru: Orange Belt Array
    Mar 2015
    310
    Yes there is. Put your laptop in sleep mode - voila GPU is disabled
    Seriously, it's the only way.
    turn off 2 cores
    Nope, either you turn off all 4 cores or none at all.
    ROG Guru: Green Belt Array Dr. Zchivago PC Specs
    Laptop (Model)Lenovo Thinkpad T410
    MotherboardASUS Crosshair V Formula - Z
    ProcessorAMD FX 9590
    Memory (part number)BLE2KIT8G3D1869DE1TX0 (8-8-8-24, 1866 MHz)
    Graphics Card #1ASUS R9 390 STRIX (OC, GAMING)
    Storage #1SG Constellation 6 TB (6x1 TB) RAID 0
    Storage #2SG Constellation 2 TB (2x2 TB) RAID 1
    CPU CoolerNoctua NH-D15
    CaseCaseLabs STH-10
    Power SupplyCorsair AX1500i
    Keyboard Microsoft Sidewinder X4
    Mouse Microsoft Sidewinder X5
    Headset Logitech G930
    Mouse Pad Perixx 900x440x3 mm + Steelseries 320x270x3 mm + ALLSOP hard pad
    Headset/Speakers Logitech G930/Altec Lansing 5.1
    OS Windows 8.1 Pro (64 bit)
    Dr. Zchivago's Avatar
    Oct 2013
    66
    609
    Quote Originally Posted by Corporal View Post
    Adding an expansion question from this response: can't this be done in the BIOS setup, if not in Windows? I seem to recall, for my old G55, being able to disable hyper threading and/or two of the four cores from the BIOS setup. I could be remembering incorrectly, though.
    Z
    Resistance is futile (at <1 Ohm).
Tags for this Thread
