Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Banned Array Hardliner PC Specs
    Hardliner PC Specs
    MotherboardASUS ROG RAMPAGE V EXTREME/U3.1 LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.1 Extended ATX Intel MOBO
    ProcessorIntel Core i7-5960X Haswell-E 8-Core 3.0 GHz LGA 2011-v3 140W BX80648I75960X Desktop Processor
    Memory (part number)G.SKILL Ripjaws 4 Series 64GB (8 x 8GB) 288-Pin DDR4 SDRAM DDR4 2800 (PC4 22400) F4-2800C15Q2-64GRK
    Graphics Card #1EVGA GeForce GTX TITAN X Hydro Copper P/N: 12G-P4-2999-KR
    Graphics Card #2EVGA GeForce GTX TITAN X Hydro Copper P/N: 12G-P4-2999-KR
    MonitorASUS ROG PG278Q 27" WQHD 2560x1440 144Hz 1ms DisplayPort Ergonomic BackLit LED G-SYNC Gaming Monitor
    Storage #1Intel 750 Series SSDPEDMW400G4R5 HHHL (CEM2.0) 400GB PCIe NVMe 3.0 x4 MLC Internal Solid State Drive
    Storage #2x2 Samsung 850 EVO 1 TB 2.5-Inch SATA III Internal SSD (MZ-75E1T0B/AM) in RAID 0
    CPU CoolerEK-FB ASUS R5E Monoblock - Acetal+Nickel; Alphacool Full Copper Rads - two 480mm and two 240mm
    CaseCorsair's Obsidian Series® 900D Super Tower Case
    Power SupplyCORSAIR AX1500i CP-9020057-NA 1500W ATX12V / EPS12V 80 PLUS Titanium certified Full Modular
    Keyboard ASUS STRIX TACTIC PRO Gaming Keyboard with Cherry MX Brown Switches
    Mouse Mionix Castor RGB Ergonomic Optical Gaming Mouse
    Headset Corsair Gaming VOID USB Gaming Headset Carbon (CA-9011130-NA)
    Mouse Pad RAZER Goliathus SPEED Edition Soft Mouse Pad - Extended
    OS Microsoft Windows 10 Pro | USB Flash Drive
    Accessory #1 TRACKIR 5 Pro Bundle: TrackIR 5 + TrackClip Pro
    Accessory #2 x12 be quiet! SILENT WINGS 2 PWM 120mm max.1500RPM/1 be quiet! SILENT WINGS 2 PWM 140mm max.1000RPM
    Accessory #3 EK-Dual DDC 3.2 PWM X-TOP (incl. pump) w/ optional 'Black' Sleeve Color
    Jun 2015
    34
    832
    After doing much reading, I am just going to use distilled water and PT Nuke.
  2. #12
    ROG Member Array radi0active's Avatar
    Sep 2015
    6
    no worry
    A good Waterooling system uses anticorosive materials, so there will be no corosion at all. You can use demineralised water. There will be also no algues. But its a good idea to use 20% antifreeze because so the cooling will prevent steaming if for any reason the temperature of the CPU will be above 90 degreese celsius. No worries about corosion, but yes 20% antifreeze with demineralised or destilated water is the best solution
  3. #13
    Hardliner PC Specs
    Jun 2015
    34
    832
    I have read that antifreeze is not good for PETG tubing.
  4. #14
    Sep 2015
    6
    yes maybe, but i think that 20% will not harm the tubes. Anyway problem will be solved if only using destilated water. I dont think that the temperatute will be above 90 degrees celsius. The motherboard has its protection and the power will be shut down if procesor temperature is rising above its limit.
  5. #15
    ROG Enthusiast Array
    Aug 2015
    25
    HydrX PM 2. Its on the web site under ' Accessories and Parts - Tubing and Coolant '.
    Unable to post the link.
    A good product, does not have Ethyl Glycol.
    Blue tinge ... the description shows color added.
  6. #16
    Hardliner PC Specs
    Jun 2015
    34
    832
    I am just going with distilled water and PT Nuke antibacterial solution (four drops per liter of distilled water). I have the equivalent of twelve 120mm radiators and they are all copper (except for the threads which are brass, but they do not come in contact with the water) and there are twelve static pressure fans blowing through them so if I overheat, then the law of thermal dynamics will be turned on its head and our main concerns in life will become much more serious than just playing with silly non-quantum computers. (BTW, it really bothers me that there are now quantum computers in the world, but we 'common folk' cannot have them. Then again, those things are too unpredictable and are likely changing life as we know it with even just the shadow governments of this planet having them. . ..)
    The only metals in contact with water in my system are copper and nickel. As long as copper and aluminum are not mixed together, and nickel and silver are not mixed together (which is why I am not using a silver kill-coil), I will not be having any problems with corrosion as long as I drain the old water and put new in, along with more unexpired PT Nuke, every eight months.
