Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Member Array Csarlorca PC Specs
    Csarlorca PC Specs
    MotherboardMaximus Gene VII
    Processor4790k Stock speed
    Graphics Card #1Asus Strix GTX 970
    Sound CardSupreme FX
    Storage #1500 gb Samsung evo 840
    CPU CoolerCM Hyper 212x
    CaseCorsair 230t
    Power SupplyCorsair CX600M
    OS Windows 10 pro
    Oct 2015
    12
    Gene VII problem with rams
    Hi i have a
    Asus Maximus VII gene
    I7 4790k stock
    2 Gskill F3-2400C10D-8GTX kits 4x4gb 10-12-12-31-2N 1.65 V
    Strix Gtx 970
    Corsair CX600 PSU
    When i activate de XMP profile to put the RAMs at 2400 mhz, the pc start, but when i run a memory stress test whit aida64 , but after 2 min aprox a BSOD appears with the error MEMORY_MANAGEMENT.
    I tested the rams on my brother PC and they works fine (he has the same kit of ram), and I use his ram in my PC, and my PC works fine so i dont know what im doing wrong.
    P.D: sorry for the bad english but i´m Chilean
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hello Csarlorca
    It's not a good idea to mix ram kits and I suspect that's what's happening.
    Reset the bios to defaults and try setting your ram manually and/or both kits separately with xmp and see if you pass the aida64 memtest. With 2 ram kits you'll have a better chance at getting them running stable setting them manually, let's hope you don't have to loosen the timings.
    Let us know if either of those passes the aida64 memtest.
    ROG Guru: White Belt Array Margus PC Specs
    Margus PC Specs
    MotherboardAsus Maximus hero VII
    Processor4790K
    Memory (part number)CMD16GXM2A2400C10
    Graphics Card #1MSI GTX 970 Gaming 4g
    Sound CardSB Recon 3D
    MonitorBENQ 2411Z
    Storage #1samsung 850 evo
    CPU CoolerLIQMAX 2 240
    Power SupplySeasonic X Platinum 1050w
    OS Windows 10 HOME
    Sep 2014
    86
    I had also sutch bsod long time ago on my hero VII its caused by bad cpu power cable. If psu new you not should worry about it. Carfully you can tighten power connector plug pins. But 600w psu is bit low maybe not the issue.
    Csarlorca PC Specs
    CaseCorsair 230t
    OS Windows 10 pro
    Oct 2015
    12
    testing 2 rams of 1 kit and windows dont boot, and the BIOS said Overcloking problem press F1 to setup, i can run the rams at 2133 mhz without any problem.
    Im gonna try to unplug plug the cpu connector
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    On the extreme tweaker tab try raising the cpu system agent voltage to 1.10v - 1.15v.
    Let us know if this gets your ram to 2400MHz.
    Csarlorca PC Specs
    CaseCorsair 230t
    OS Windows 10 pro
    Oct 2015
    12
    AIDA64 stop the test after 5 minutes, the error says Warning: Hardware failure detected! Test stopped
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Did you raise the cpu system agent voltage to 1.10v - 1.15v?
    You have ram instability if it runs at 2133MHz and you get overclocking failed at 2400mhz, raising the cpu system agent voltage can help with this. If it still fails after raising the cpu system agent voltage raise the Dram voltage to 1.68v.
  8. #8
    Csarlorca PC Specs
    CaseCorsair 230t
    OS Windows 10 pro
    Oct 2015
    12
    i tried and it doesn't work
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    All right thank you
    If you have the two sticks in the red slots try them in the black slots and enable xmp.
    If it still fails reset bios to defaults and try one stick in all four slots.
  10. #10
    Csarlorca PC Specs
    CaseCorsair 230t
    OS Windows 10 pro
    Oct 2015
    12
    i tried that before and with 2 of the rams on the red or black slot and xmp enable the pc wont boot (it stay in a loop, try to star but it can't), and when i put 1 ram in each slot windows boot but many BSODs appears, maybe because 4 gb isn't enought
Tags for this Thread
