Results 1 to 8 of 8
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,461
    EKWB XLC Predator 360 Installation Guide
    New expandable watercooling system from EKWB designed to hold CPU and GPU if need in loop.
    Build with best watercooling parts on market as Coolstream PE radiator (240/360) and Supremacy CPU Block (MX Version), famous DDC PWM pump and one of best radiator fans on market Vardar F4 (2200RPM)...
    https://youtu.be/dS9jGhmwClM
    Maybe best option for people who can't afford 500-600e worth custom loops.
    I think 10/13mm EKWB compression fittings and clear/red or black tubes are perfect for this cooler
    but that's personal taste and choice.
    Vlada011 PC Specs
    Mouse Logitech G900
    Vlada011's Avatar
    Oct 2013
    20
    1,461
    EKWB Predator 240 - ASUS GTX980Ti Poseidon How to Drain and Refill - Oc aholic video
    https://youtu.be/Z7pslV1yjS0
    Interesting... Probably some of people decide to go with two Predator 240 Instead 360 version and one connect to CPU, other for 1-2 GPU.
    Vlada011 PC Specs
    Mouse Logitech G900
    Vlada011's Avatar
    Oct 2013
    20
    1,461
    Only Quick disconnect are not sexy ...Like from toilet.
    But I understand, they didn't want to be too expensive kit.
    Koolance make some nice 10/13mm Black/Silver...
    I think this EKWB Predator 360 is enough too cooldown CPU and R5E (Monoblock) and one Fury X.
    Banned Array Hardliner PC Specs
    Hardliner PC Specs
    MotherboardASUS ROG RAMPAGE V EXTREME/U3.1 LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.1 Extended ATX Intel MOBO
    ProcessorIntel Core i7-5960X Haswell-E 8-Core 3.0 GHz LGA 2011-v3 140W BX80648I75960X Desktop Processor
    Memory (part number)G.SKILL Ripjaws 4 Series 64GB (8 x 8GB) 288-Pin DDR4 SDRAM DDR4 2800 (PC4 22400) F4-2800C15Q2-64GRK
    Graphics Card #1EVGA GeForce GTX TITAN X Hydro Copper P/N: 12G-P4-2999-KR
    Graphics Card #2EVGA GeForce GTX TITAN X Hydro Copper P/N: 12G-P4-2999-KR
    MonitorASUS ROG PG278Q 27" WQHD 2560x1440 144Hz 1ms DisplayPort Ergonomic BackLit LED G-SYNC Gaming Monitor
    Storage #1Intel 750 Series SSDPEDMW400G4R5 HHHL (CEM2.0) 400GB PCIe NVMe 3.0 x4 MLC Internal Solid State Drive
    Storage #2x2 Samsung 850 EVO 1 TB 2.5-Inch SATA III Internal SSD (MZ-75E1T0B/AM) in RAID 0
    CPU CoolerEK-FB ASUS R5E Monoblock - Acetal+Nickel; Alphacool Full Copper Rads - two 480mm and two 240mm
    CaseCorsair's Obsidian Series® 900D Super Tower Case
    Power SupplyCORSAIR AX1500i CP-9020057-NA 1500W ATX12V / EPS12V 80 PLUS Titanium certified Full Modular
    Keyboard ASUS STRIX TACTIC PRO Gaming Keyboard with Cherry MX Brown Switches
    Mouse Mionix Castor RGB Ergonomic Optical Gaming Mouse
    Headset Corsair Gaming VOID USB Gaming Headset Carbon (CA-9011130-NA)
    Mouse Pad RAZER Goliathus SPEED Edition Soft Mouse Pad - Extended
    OS Microsoft Windows 10 Pro | USB Flash Drive
    Accessory #1 TRACKIR 5 Pro Bundle: TrackIR 5 + TrackClip Pro
    Accessory #2 x12 be quiet! SILENT WINGS 2 PWM 120mm max.1500RPM/1 be quiet! SILENT WINGS 2 PWM 140mm max.1000RPM
    Accessory #3 EK-Dual DDC 3.2 PWM X-TOP (incl. pump) w/ optional 'Black' Sleeve Color
    Jun 2015
    34
    832
    Jay compares Predator:
    Vlada011 PC Specs
    Mouse Logitech G900
    Vlada011's Avatar
    Oct 2013
    20
    1,461
    Did I mix something in my head or EKWB offer different tops for Supremacy CPU block in different colors?
    Now I see whole CPU block different Edition, but I think they offered only top replacement before, maybe for previous model.
  7. #7
    ROG Enthusiast Array EK Luc PC Specs
    EK Luc PC Specs
    MotherboardAsus ROG Rampage V Edition 10
    Processori7-6800K
    Memory (part number)2 x G.SKILL TridentZ (3200C16Q-16GTZB)
    Graphics Card #1Asus GTX 1070 ROG Strix (O8G-GAMING)
    Graphics Card #2Asus GTX 1070 ROG Strix (O8G-GAMING)
    CPU CoolerCustom Watercooling
    Casebe quiet! Dark Base Pro 900
    Power SupplyCorsair AX860i
    OS Win10
    EK Luc's Avatar
    Nov 2014
    42
    Quote Originally Posted by Vlada011 View Post
    Yes Vlada, it was for the previous version of the Supremacy. With the Supremacy EVO, we didn't go this way.
  8. #8
    Vlada011 PC Specs
    Mouse Logitech G900
    Vlada011's Avatar
    Oct 2013
    20
    1,461
    I remember I saw on site different tops and suddenly they gone.
    But that was for previous version.
