Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    ROG Enthusiast Array
    Aug 2015
    29
    G751jt Lid making noise when opening and closing lid
    My new g751jt making a loud click sound when opening and closing the lid. It was perfectly fine just a while ago. I am so mad at asus for making this sorts of hardware.
    did anyone else had this issue ? how to fix it ? please say don't say go to customer service .
    ROG Guru: Orange Belt Array
    Mar 2015
    310
    Please record the sound/video. My g751jy lid does "click" a little when I move it, not sure if it's the same as yours.
    Aug 2015
    29
    Mar 2015
    310
    You could open it up and see if all the screws are tight.
    ROG Member Array
    Sep 2015
    9
    6
    Quote Originally Posted by Corporal View Post
    where are the screws ?
    Aug 2015
    29
    where are the screws ? not seeing any nearby
  7. #7
    Mar 2015
    310
    Open the rear speakers cover, open the palm rest, unscrew 4 screws at the bottom of the display and remove the display cover. Then see if there are any untight screws that connect the display to the base.
  8. #8
    Aug 2015
    29
    will I loose warranty if I do so?
  9. #9
    ROG Guru: Green Belt Array
    Dec 2014
    32
    533
    Quote Originally Posted by Nayem33397 View Post
    Sadly opening your laptop up in the manner Corporal is suggesting will void your warranty, such advice really should come with this disclaimer.
    On the flipside Asus has no way to determine that you have done so if there is nothing physically wrong.
    It does kind of sound like there is unwanted play from a loose screw.
    My advice is first to exchange the unit, if not feasible then to have warranty service done. I don't recommend self service as if you error in some way (i.e. scratch/dent some plastic) then you've potentially tossed your warranty which could lead to a very expensive repair later.
  10. #10
    Mar 2015
    310
    Chances are, there is no screw lose and it's just cheap plastic making noise. I don't recommend sending it to asus service, because it will take a long time and very likely won't fix anything. It's more likely that your laptop will be sent back with scratches or components missing. If it's just plastic, they will tell you it's normal and send it right back to you(after a few weeks).
    Self-service is the only way of fixing screen bezel putting pressure on the screen for example.
Tags for this Thread
