10-05-2015 02:45 AM - last edited 3 weeks ago by ROGBot
10-05-2015 04:31 AM
10-30-2015 08:04 AM
Menthol wrote:
It is very hard for me to see the pictures, do you have the 8 pin power cable connected along with the 24 pin?
What do you mean by test GPU? you can use the on die GPU for video, is that test GPU in the top X16 PCIE slot or is it in the X1 very top slot, it is hard for me to tell by the pictures but it should be in the X16 slot
10-05-2015 01:08 PM
10-30-2015 08:02 AM
NemesisChild wrote:
That Corsair PSU would not be my choice but most of the web reviews seem favorable.
Have you tried posting with only one memory stick and different dimm slots?
Recheck the CPU socket for bent or missing pins.
Remove all USB devices, disconnect the drives then try posting with only essential hardware.
You may have a short, remove the MB from the case and test on a cardboard box.
10-30-2015 09:39 PM
03-25-2016 05:36 PM
03-25-2016 06:10 PM
03-25-2016 06:56 PM
03-25-2016 07:00 PM
deybdeybdeyb wrote:
@Nate152, actually no code as the board wont power up. Same as the OP's post, motherboard LEDs are just on. And pressing power wont power on the system. Note that I changed PSU from CM V1000 to Seasonic P1050 which technically isolated the PSU. 🙂
I'm still isolating (except resitting the CPU, perhaps tomorrow I'll do it). For now, I did some BIOS settings:
SVID support: disabled
Anti power surge: Disabled
