Results 1 to 9 of 9
    ROG Guru: Orange Belt Array
    Sep 2013
    28
    306
    Asus Strix 980 Ti - small rattle noise when fans are spinning.
    Hello. Its my next topic here, but i am left only with one problem .My card is Asus Strix 980 Ti.When i am launch a game, and when fans ramps up, i can hear small rattle noise. Then after 5 second noise is gone. Is this normal or i must rma card?
    Should i be worried about this?
    No there is not any cables interfering. I checked it. So live with this or rma card?Its only small rattles for few seconds when fans are spinning , then noise is gone.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,360
    Hello sde444
    That's something to take up with tech support, they will advise you if you should rma your strix 980ti or not.
    Sep 2013
    28
    306
    Here is the noise what i am talking about:
    I have the same rattle noise when fans coming to spin up. Afer a while noise is gone. So iguess its not normal?
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,360
    No the noise is not normal, get a hold of tech support and explain the problem to them.
    There's not much we can do for you here.
    Sep 2013
    28
    306
    The noise is only when fans are starting ( accelerating ). Then after a moment on higher rpm noise is gone and its ok. What do you think about it?
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,360
    It's a tough call, as long as it doesn't get any worse I might not worry about it, but if it does get worse then it's a problem. if it gets worse after the warranty period it's even a bigger problem.
  7. #7
    Sep 2013
    28
    306
    It gradually disappear. And its sound like this:
    https://www.youtube.com/watch?v=4ceIxnzd97M
  8. #8
    ROG Member Array
    Oct 2015
    12
    Now that you mention it ... my 980ti strix also rattles. It's the first fan and if I slightly push up the coolers housing it disappears.
    Seems like a grinding/rattling noise.
    I am sending mine back.
  9. #9
    ROG Member Array
    Oct 2015
    12
    716
    I also did a quick sound record before returning the card so I have some evidence.
    https://www.youtube.com/watch?v=jDjZ0FgIIfU
