10-08-2015 05:29 PM - last edited on 03-06-2024 01:51 AM by ROGBot
10-08-2015 10:57 PM
10-09-2015 06:47 AM
aeolisio wrote:
You dont need the pad most of the air intake is from the ports and keyboard but it helps. I use a notepal u3 as do most the people with the g751 at our office. It helps and even though the g751 has fantastic cooling by itself extras cooling isnt going to hurt anything and can only prolong hardware.
10-09-2015 07:02 AM
10-09-2015 09:19 AM
Clintlgm wrote:
Are you monitoring your actual CPU and GPU Temps???? that should be the determining factor as to whether you need to use a cooling pad. I would suggest Hwinfo 64 from the sensors of that program you can monitor your CPU GPU LOad, Temps and Fan Speeds. If your temps are going up very much at all with your notebook flat on a soft surface then you would be doing yourself a good thing to prevent this any thing that increases temp should be avoided if possible.
10-09-2015 01:32 PM
10-09-2015 02:05 PM
Clintlgm wrote:
Yes you need to pay attention to these temps with these powerful notebooks
10-09-2015 04:48 PM
10-09-2015 05:10 PM
10-10-2015 06:47 AM
