Results 1 to 2 of 2
    ROG Member Array
    Oct 2015
    8
    Exclamation Random power failures
    Well, I'm new to the forums, so if this isn't the right place, let me know.
    Did a dxdiag, here's the specs
    System Information
    Time of this report: 10/11/2015, 15:49:37
    Machine name: SARAH-LAPTOP
    Operating System: Windows 10 Pro 64-bit (10.0, Build 10240) (10240.th1.150916-2039)
    Language: English (Regional Setting: English)
    System Manufacturer: ASUSTeK COMPUTER INC.
    System Model: G46VW
    BIOS: G46VW.205
    Processor: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz (4 CPUs), ~2.5GHz
    Memory: 8192MB RAM
    Available OS Memory: 8078MB RAM
    Page File: 4365MB used, 18712MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: 12
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    Miracast: Available, with HDCP
    Microsoft Graphics Hybrid: Supported
    DxDiag Version: 10.00.10240.16384 64bit Unicode
    Not long after I got it, it started having random power failures. First it locks up, but for only a second, then makes this "winding down" noise and then dies. It seems like the PC has enough time to save what I had up to the RAM or something, because I don't ever seem to lose much, if at all. But is this a software or hardware problem or both?
    I purchased it 2013/01/26, so I don't think I still have it under warantee, but I did have to take it in once before for a charging issue where the port was loose. I often max the memory and/or disc, and I'm not quite sure how to fix that. I'm more tech savvy than most people, but I'm not good enough to know what this is or how to stop overloading myself. I'm really bad about having a bunch of things running, but shouldn't a gaming laptop be able to handle it?
    Anyway, what do you guys think?
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,668
    Hi shadowguardian0
    Maybe try a post here? https://rog.asus.com/forum/forumdisp...ries-Notebooks
    I really don't know much about laptops....but maybe disk problem? have you run checkdisk for errors or some disk health software?
    Any clue in Windows Error logs?
    Did they fix the loose port?
Tags for this Thread
