If multiple GPU use is a problem, you need to disable the GPU use you don't like.
You might try disconnecting the Intel video out cable from any monitor it may be connected to, and disabling the Intel video either via a windows display setting or in the bios. Then check that every game only sees the Nvidia graphics as an option.
You might be jumping to the Intel video as a power saver option.
