Results 1 to 4 of 4
    New ROGer Array
    Oct 2015
    3
    Hero VIII - Side panel in BIOS does not display correct CPU OC or other data,
    3 Things have started going wrong since i upgraded bios to 101.
    1. The side panel in bios that displays current system config (CPU speed ect) displays 3500mhz no matter what I do. Though CPUZ shows my overclock and so does my ROG front panel
    2. RealBench reports when I run it that it cannot pull my system specs
    3. When booting the screen that use to display ASUS logo and % Overclock. No longer displays my systems OC.
    Anyone else having these issues or know a solution?
    New ROGer Array
    Oct 2015
    3
    bump
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    1. I wouldn't worry about what the side panel says.
    2. Reinstall Realbench.
    3. If I'm not mistake, the 0% overclock is from running the 5 Way Optimization. Since you updated the BIOS, your system is back to stock defaults. Run the 5 Way Optimization process again.
    New ROGer Array
    Oct 2015
    3
    4405
    Thanks for info.
    Sad that you don't get the cool OC boot screen with manual overclocks.
Tags for this Thread
