Results 1 to 6 of 6
    ROG Guru: White Belt Array Jagdseelen PC Specs
    Jagdseelen PC Specs
    MotherboardASUS MAXIMUS VIII HERO
    ProcessorIntel i7-6700k @4.8ghz
    Memory (part number)G-Skill Trident Z F4-3200C14D-16GTZ
    Graphics Card #1EVGA GTX 1080 ti SC2 Gaming
    Sound CardOnboard
    MonitorASUS ROG SWIFT PG278Q and Samsung C24F390FHE 23.5"
    Storage #1Samsung 960 Pro M.2 1TB SSD
    Storage #2Seagate 3tb
    CPU CoolerCorsair Hydro Series H110i GTX
    CaseCorsair Graphite 760T Black
    Power SupplyEVGA SuperNOVA G3 750W Modular
    Keyboard Logitech G910 Orion Spectrum
    Mouse Logitech G900 Chaos Spectrum
    Headset Sennheiser G4ME ZERO
    Mouse Pad Logitech G240
    OS Windows 10 Pro x64
    Network RouterNetgear D8500 (Beta Sample)
    Accessory #1 ASUS ROG Front Base
    Accessory #2 ASUS DRW-24D3ST Black SATA DVD Burner
    Accessory #3 Oculus Rift Touch Bundle (New)
    Jagdseelen's Avatar
    Aug 2015
    11
    117
    Thumbs up ROG Front Base does not include USB2 header required for Firmware update!
    ROG Front Base does not include USB2 header required for Firmware update. I am unable to find a store that sells one here in Australia and have tried the following.
    1/ Asked local computer stores if they sell one.
    2/ Contacted the online reseller Scorptec that sold me the ROG Front Base.
    3/ Contacted ASUS Australia about the problem
    4/ searched Ebay for one
    None could or would help.
    Without this USB2 header I am unable to update the firmware on the ROG Front Base from firmware v40 to firmware v48 which is essential to making it functional with a ASUS ROG Maximus VIII Hero motherboard and rendering it as useful as a piece of glorified plastic.
    After paying $110 for it including delivery. I can only think of one thing to do with it which would result in the ASUS Rep that decided what would be bundled it walking awkwardly for weeks afterwards.
    Unhappy Jan!
    New ROGer Array
    Jul 2014
    1
    Well that sucks !!!
    Ask for refund and don't buy ASSUS (sorry ASUS) again...DOH !!!
    Jagdseelen PC Specs
    Sound CardOnboard
    Jagdseelen's Avatar
    Aug 2015
    11
    117
    Quote Originally Posted by meniac View Post
    I know you'd think they would at least warn you that you need it for updating the firmware in the product description.
    Banned Array Hardliner PC Specs
    Hardliner PC Specs
    MotherboardASUS ROG RAMPAGE V EXTREME/U3.1 LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.1 Extended ATX Intel MOBO
    ProcessorIntel Core i7-5960X Haswell-E 8-Core 3.0 GHz LGA 2011-v3 140W BX80648I75960X Desktop Processor
    Memory (part number)G.SKILL Ripjaws 4 Series 64GB (8 x 8GB) 288-Pin DDR4 SDRAM DDR4 2800 (PC4 22400) F4-2800C15Q2-64GRK
    Graphics Card #1EVGA GeForce GTX TITAN X Hydro Copper P/N: 12G-P4-2999-KR
    Graphics Card #2EVGA GeForce GTX TITAN X Hydro Copper P/N: 12G-P4-2999-KR
    MonitorASUS ROG PG278Q 27" WQHD 2560x1440 144Hz 1ms DisplayPort Ergonomic BackLit LED G-SYNC Gaming Monitor
    Storage #1Intel 750 Series SSDPEDMW400G4R5 HHHL (CEM2.0) 400GB PCIe NVMe 3.0 x4 MLC Internal Solid State Drive
    Storage #2x2 Samsung 850 EVO 1 TB 2.5-Inch SATA III Internal SSD (MZ-75E1T0B/AM) in RAID 0
    CPU CoolerEK-FB ASUS R5E Monoblock - Acetal+Nickel; Alphacool Full Copper Rads - two 480mm and two 240mm
    CaseCorsair's Obsidian Series® 900D Super Tower Case
    Power SupplyCORSAIR AX1500i CP-9020057-NA 1500W ATX12V / EPS12V 80 PLUS Titanium certified Full Modular
    Keyboard ASUS STRIX TACTIC PRO Gaming Keyboard with Cherry MX Brown Switches
    Mouse Mionix Castor RGB Ergonomic Optical Gaming Mouse
    Headset Corsair Gaming VOID USB Gaming Headset Carbon (CA-9011130-NA)
    Mouse Pad RAZER Goliathus SPEED Edition Soft Mouse Pad - Extended
    OS Microsoft Windows 10 Pro | USB Flash Drive
    Accessory #1 TRACKIR 5 Pro Bundle: TrackIR 5 + TrackClip Pro
    Accessory #2 x12 be quiet! SILENT WINGS 2 PWM 120mm max.1500RPM/1 be quiet! SILENT WINGS 2 PWM 140mm max.1000RPM
    Accessory #3 EK-Dual DDC 3.2 PWM X-TOP (incl. pump) w/ optional 'Black' Sleeve Color
    Jun 2015
    34
    832
    For what exactly are you looking?
    Jagdseelen PC Specs
    Sound CardOnboard
    Jagdseelen's Avatar
    Aug 2015
    11
    117
    Quote Originally Posted by Hardliner View Post
    USB2 Header as pictured in link below
    http://www.pcper.com/image/view/4552...n=node%2F61042
    ROG Member Array RxL-Soul PC Specs
    RxL-Soul PC Specs
    MotherboardRampage V Extreme
    Processori7 5930k
    Memory (part number)G.Skill Ripjaws 4 16GB DDR4 3000MHz
    Graphics Card #1GTX 980 Ti Superclocked+ acx 2.0+
    MonitorAsus PG248Q + Benq GL2460HM
    Storage #1Samsung 960 Evo 250GB 950 Pro 256GB
    Storage #2Samsung 840 EVO 250GB 850 Evo 250GB
    CPU CoolerCorsair H110i GTX
    CaseCorsair 900D
    Power SupplyEVGA SuperNova G2 750w
    Keyboard Razer Blackwidow Chroma
    Mouse Razer Deathadder Chroma + Razer Naga Chroma
    Headset Razer Kraken Chroma
    Mouse Pad Razer Goliathus Control Extended
    Headset/Speakers Razer Leviathan
    OS Windows 10 Pro 64bit
    Sep 2015
    24
    Quote Originally Posted by Jagdseelen View Post
    Unhappy Jan!
    Look inside your motherboard box best option since they give Q-Tips inside your box for other motherboard cables i.e for power led and so on i got 2x with my maximus vii hero 1x usb and the other one
