Results 1 to 2 of 2
    New ROGer Array
    Nov 2015
    1
    Sli water block connector for poseidon
    Hi guys.
    Quick question: did ASUS or any other brand ever made a VGA water block SLI connector for the poseidon?
    This card has the G 1/4 ports aiming directly to the side panel.
    A quick solution to connect a cutom loop would be to put a couple of angled fittings.
    Since I plan to put on another poseidon, I think it would be much more stilish to have a water block connector like Koolance or others (they usually have the ports aiming up / down).
    It would be great if Asus did made one with a ROG / ASUS illuminated logo. I couldnt find one on the web.
    Does anybody knows if there is any of those connector that can be connected to the poeisdon ports even with some fittings on the back?
    Many thanks!
    ROG Enthusiast Array andlaw PC Specs
    andlaw PC Specs
    MotherboardRAMPAGE VI EXTREME ENCORE
    ProcessorIntel® Core™ i9-10900X @ 5GHz AC 1.359v
    Memory (part number)CORSAIR Dominator Platinum 32GB (CMD32GX4M4B2400C10)
    Graphics Card #1EVGA GeForce RTX 2080 SUPER FTW3 HydroCopper
    MonitorASUS VG248QE 24" 144Hz
    CPU CoolerCustom Water Loop [Alphacool/ EKWB]
    CaseLian Li 011D XL-X
    Power SupplyCORSAIR AX1200i Platinum
    Keyboard Logitech G910 Orion Spark
    Mouse Razer DeathAdder Black Edition
    Headset Audio-Technica M50X Professional
    Mouse Pad ROG Sheath XL
    Headset/Speakers Samsung H551 soundbar
    OS Windows 10
    Network RouterLinksys WRT1900ACS
    Accessory #1 Mayflower Objective2 w/ ODAC - Rev. B Combo
    andlaw's Avatar
    Jun 2015
    20
    74
    might take a look at my thread, I was in similar boat a few months back.. angled fittings are how its done unless your going full water block in which you can use a parallel bridge by EK
    https://rog.asus.com/forum/showthrea...-GTX-Poseidons!
