11-10-2015 02:35 AM - last edited on 03-06-2024 01:34 AM by ROGBot
11-21-2015 01:40 AM
kelso1108 wrote:
Hey guys,
I don't know if anyone has ever encountered this problem before. I've tried Googling and searching this forum to see if anyone has had any problems with their G751 batteries. For some reason, mine won't charge beyond 83-87%. I understand the concept of battery wear, but even if my battery's capacity is at around 50,000+ mWh as CPUID and Battery Bar say, I should still be able to charge up to 100%.
My battery started behaving like this on Sunday (November 8th), while I was backing up my laptop to an external hard drive. I noticed that the charging indicator light was still amber, when it should have been green. When I checked the charging status on the taskbar, it said it was at 87% and that the charge would be complete in about 11 minutes. Half an hour or so later, it was still at 87% and now, when my laptop is unplugged, my battery can survive for just over an hour (compared to the 2+ to 3+ hours it could survive on battery power the week preceding Sunday.
My laptop's barely 11 months old so I think it's pretty unusual for its battery to behave like this. I've tried updating its driver through Device Manager but it's still behaving the same way.
Here are its stats, according to CPUID:
Designed Capacity: 90,000 mWh
Full Charge Capacity: 50,865 mWh
Current Capacity: 42,570 mWh
Wear Level: 44%
Maximum Charge Level: 83%
Here are the stats according to the Battery Report on the command prompt:
Design Capacity: 90,000 mWh
Full Charge Capacity: 50,910 mWh
I've tried calibrating the battery to see if it would fix the issue, but I don't think it's properly calibrating because the battery's not charging to full capacity.
Any thoughts?
11-21-2015 03:49 AM
11-21-2015 09:41 AM
11-21-2015 01:37 PM
SoapTurtle wrote:
DESIGN CAPACITY 90,000 mWh
FULL CHARGE CAPACITY 52,890 mWh
The fk? seriously. I have only had this laptop for 4 months
11-21-2015 11:09 PM
aeolisio wrote:
Batteries are consumable like brakes on a car everyone uses them differently. We had a g751 thats a year old under heavy usage with the battery still at %98 but it was never used off cord for more then an hour. You should still be under warranty rma it or rebuild the pack its not that hard. If you do a rebuild youll have more control over the cells you use and can pick some panasonic 3400 or 3600 cells.
11-22-2015 03:09 AM
Maiko wrote:
What is a rebuild? I filled out the entire RMA form and it failed to submit. Saying that their was an error.
Either way, this is so frustrating.
11-22-2015 07:09 AM
11-22-2015 11:18 AM
11-22-2015 02:07 PM
SoapTurtle wrote:
Even if i rebuild the battery i'm going to have to put it in myself. And i really dont want to risk tampering with the computer to have it fail. I never kept my battery on the chagrer always let it off when i wasn't gaming much because i thought that was bad. Do you think that could be the problem? Even so for 4 months this is the worst battery on any laptop i have ever had. My last one survived 2 years on me basically doing the same thing and that wasn't even the problem.
