Results 1 to 5 of 5
    New ROGer Array
    Nov 2015
    4
    g73 motherboard to lan & audio connector removal, how?
    I need to remove the two connectors, one from the motherboard to audio and the other from motherboard to LAN. they are the only all metal connectors on the board and have shielded cables, both marked 01PA. not sure if I need to lift, pull from the cable side, unlatch something or what edge to lift from. All videos I could find do not show this detail. Any advice would be appreciated. Goal is to repaste cpu and video. Getting half screen of lines on the left and half of bizarre color on the right, figured I'd start with a repaste and then LVDS cable before going further, unless someone has a better idea of whats wrong. Got a black screen on wake, rebooted and got bad video, vid card finned area was too hot to touch, but I don't know if its always like that. fans and air ducts were clear. connector is the metal one to the left of the blue cable end.
    TIA
    tom
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    96
    2,493
    New ROGer Array
    Nov 2015
    4
    Thanks, but I've already seen that document and it just says remove the cable, not how it comes off...
    New ROGer Array
    Nov 2015
    4
    New ROGer Array
    Nov 2015
    4
    I got it, you need to pull the tape all the way back to the black then there is a white plastic plug INSIDE the metal part that pulls straight back. if you peel back the black fabric a bit there is enough room to push it back with a tiny jewelers screwdriver a little bit on each side until it slides out
