G750JW: Snapped Hinges. Replacment help?
Ledan
The hinges on my G750JW ( or some other G750) have snapped. Its the ones that actually support the screen, behind the bottom left and right screws on the frame. Not the ones on the back that are bigger.
Is there anywhere i can buy replacements? Should i buy a whole new frame mount for the screen? (Currently the screen is only supported by the plastic frame and is breaking bit by bit).
Wulff
those are the ones you need: http://www.asusparts.eu/en/partfinder/Asus/Notebook/G%20Series/G750JW#Hinge there is a left one and a right one obvious 😉 perhaps with those partnumbers you might be able to find them on ebay or whereever as well
