Results 1 to 5 of 5
    ROG Member Array R2D2Mares PC Specs
    R2D2Mares PC Specs
    MotherboardAsus ROG Maximus VII Formula
    ProcessorIntel Core i7-4790K 4.0GHz Quad-Core
    Memory (part number)Corsair Vengeance Pro 32GB (4 x 8GB) DDR3-2400 Memory
    Graphics Card #1Asus ROG Poseidon GT​X980 4Gb D​DR5
    MonitorViewsonic
    Storage #1Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
    Storage #2Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive
    CPU CoolerXSPC RaySt​orm custom
    CaseCorsair 760T White ATX Full Tower Case
    Power SupplyEVGA 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply
    Headset/Speakers Logitech Z623 200W 2.1ch Speakers
    OS Windows 7/10 Pro 64
    Accessory #1 LG WH14NS40 Blu-Ray/DVD/CD Writer
    Nov 2015
    12
    The build in audio card in M-VII z97 MoBo is ASIO compatible?
    If it is compatible... is there additional drivers needed?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hello R2D2Mares
    If you're referring to audio streaming there should be no additional driver needed in fact I'm pretty sure there aren't any additional drivers.
    R2D2Mares PC Specs
    MonitorViewsonic
    Nov 2015
    12
    I need the ASIO Drivers for low latency usin DAW software as Sonar / Live / Pro tools
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    I know some other things get installed with the realtek audio driver like sonic radar and sonic studio, I'm not sure what all installs with it. I don't install the realtek driver I just use the jacks on the front of my case.
    Does this help?
    http://rog.asus.com/321242014/maximu...-sonic-studio/
    maybe you're talking about Deamon tools on the motherboard DVD?
    R2D2Mares PC Specs
    MonitorViewsonic
    Nov 2015
    12
    To your question the answer is no... I realize that there is no ASIO drivers to the RealTek chip in this MoBo... It is possible to use ASIO4ALL but have no choice to use an USB Audio Interface like m-Audio FastTrack.
Tags for this Thread
