11-22-2015 11:58 AM - last edited on 03-05-2024 10:25 PM by ROGBot
11-22-2015 12:55 PM
11-22-2015 03:45 PM
Menthol wrote:
The ASUS Front Base is a different device than the OC Panel
https://www.asus.com/us/Motherboard-Accessories/ROG_Front_Base/
Try uninstalling the front base drivers, you may need to go to the motherboard site and update the OC panel firmware
https://www.asus.com/us/Motherboards/RAMPAGE_V_EXTREME/HelpDesk_Download/
11-29-2015 12:04 PM
0Shin0 wrote:
Wow thanks! You Sir are a life saver!! I just did that and everything works great. You saved me from a lot of hassle by taking this to the re-seller.
11-29-2015 01:21 PM
11-29-2015 02:30 PM
Menthol wrote:
OC Panel firmware is on ASUS site for your motherboard, instead of checking an OS version, check Others, Firmware
http://www.asus.com/us/Motherboards/RAMPAGE_V_EXTREME/HelpDesk_Download/
02-14-2016 11:00 AM
02-18-2016 08:04 AM
02-18-2016 08:17 AM
02-18-2016 12:14 PM
