G51 Series thermal design differences
Retired
Not applicable
Here is a comparison over the different G51 Series thermal differences. i think many of you might think we used the same thermal design, but we have actually improved it in every update.
G51Vx - Single heatpipe design covering the northbridge and cpu
G51J- Dual heat pipe for the cpu,
G51Jx- has an additioanl heatsink over the GPU
232
4 REPLIES 4
V2-V3
Thanks for the pictures and follow up information! I didnt know each revision had significant changes to the cooling system.
Is it useful to use a Notebook cooler? Witch one is recommended?
V2-V3
Richard,
I Recommend the Antec notebook coolers, depending on your notebook size this one may work for you:
Notebook Cooler 200
http://store.antec.com/Product/notebookcooler/notebook-cooler-200/0-761345-75019-6.aspx
grungeboy
are those different fan/heatsink units interchangeable? specifically, if i bought one for a JX model do you think it would work on my VX model?
