Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    ROG Guru: White Belt Array gene-iv-ocz-revo3-240 PC Specs
    Laptop (Model)HP Envy 17
    MotherboardROG Rampage V Edition 10 Bios 0801
    Processori7-5820k 4.3 OC adaptive 4.0 Cache
    Memory (part number)Ballistix 32GB kit (8GBx4) DDR4-2666 CT6311990 CL12-12-12 33 1T
    Graphics Card #1Asus Strix GTX970
    Monitor4 AOC 2367M 2 top 2 bottom
    Storage #1Samsung 950 Pro 512GB OS Drive
    CPU CoolerCorsair H110iGT
    CaseCorsair 750D Airflow Edition
    Power SupplyCorsair AX1200i + Link commander mini
    Keyboard Corsair Strafe RGB Silent
    Mouse ROG GX1000 Laser Gaming Mouse
    Headset Wired Beats Studio 2.0
    Mouse Pad ROG GM50 Gaming Mouse Pad
    Headset/Speakers Cerwin Vega XD4's
    OS Windows 10 Pro
    Network RouterLinux custom
    Accessory #1 6 Kingston SSDNow V300 SV300S37A/120G intel raid0
    Accessory #2 4 case Noctua NV-P14s redux-1500 PWM, 2 AIO PUSH
    Accessory #3 4 Noctua NF-A14 iPPC-3000 PWM AIO PUSH/PULL
    gene-iv-ocz-revo3-240's Avatar
    Jan 2014
    79
    Samsung 950PRO cooling or heat sink
    Has anyone installed a heat sink on the Samsung 950PRO? I have done some testing using ISO disk copy/clone/move.
    Even using ATTO the drive without cooling hits 75C and throttles so I ended up adding a fan to blow right
    at it and that solved the overheat problem but is really ugly sitting on top of the video card lol!
    ROG Guru: Yellow Belt Array
    Nov 2015
    154
    That would prolly have to be a custom job I don't think anyone makes any cooling solutions for M.2 yet.
    I heard they pumped out heat and had some issues with thermal throttling and for the price and limited storage I went for normal 960GB Sata SSD's.
    There are some nice cases around that, lol have a big fan on the side over the GPU's, and over the motherboard like the Thermaltake Armour Revo which I have, its a nice case.
    Though another way you might skin the cat is to have a top radiator with the fans on it on suck (or just fans at the top if your on a custom loop) which would blow air over the M.2 socket/Dimm sockets like I've done as my active Corsair Dimm coolers, have metal clips I wasn't happy fitting as they posed a risk of shorting out on the back of the first GPU card.
    That would also stop you having to invalidate your warranty on the M.2.
    Personally I think your best option is perhaps a different case, failing that you'd prolly have to look towards Mapilins or another electronics outlet for some small static heatsinks, but attaching them would most likely invalidate your warranty, and or having to remove them for any reason risk physical damage.
    A Air cooling solution with a choice case seems like a better option to me, also perhaps a better looking one.
    ROG Enthusiast Array kaese PC Specs
    kaese PC Specs
    MotherboardX99 Rampage V Extreme
    Processor5820K
    Oct 2014
    25
    65
    Depending on your real-life workload (and your aesthetic demand) you may judge my solution. As the controller only consumes a few watts in may be sufficent just to glue a small, passive heat sink onto it.
    Such as a VRAM heat sink, or in case you dont habe any simple metalplate might do the job improving temps (actually that is what I did because cost is 0 and time is 1 min ;-)).
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    21
    1,475
    On e-bay or similar site is possible to find copper heatsinks, best in black or silver cooler but could be and other.
    They could help lot. If temp stay on 75-80C no problems.
    Maybe could help and modified VRM heatsink from sold old graphic card similar size as whole M.2
    I will use that, why not. 3 points of thermal paste and they will stay.
    Arctic Alumina is best for that purpose but I afraid could be harder to remove later.
    She is pretty strong, maybe is better Ceramique or some similar thicker paste.
    Example...
    http://www.performance-pcs.com/mobo-...mosfet-coolers
    I anyway keep 120mm fan in DVD bay and he is very close to M.2 slot on R5E.
    With heatsink temps could drop 10-15C, maybe even more.
    OS Windows 10 Pro
    Jan 2014
    79
    Thanks for some ideas. I want to keep the sticker on because I got it from micro center and if anything happens or a better one comes out I'll return it easily.
    I hoped there was a clip on or slide on heatsink out there that someone may know of. My case has 8 140mm noctua fans in there, 4 doing push/pull on the h110 in the top of the case and a 120 sitting on the video card so air flow was not a problem and did not help until I put that 9th fan in there.
    FYI the 3000rpm noctuas pulling aren't really as loud as the reviews say and if you use a shroud they have no whine.
    The drive will not go above 75C and trust me I tried for hours with no fans on running the drive at max r/w io.
    I'm going to go thru the heatsink box and see what I can come up with. I'm guessing some thermal compound won't hurt the sticker and though it's not going to be very efficient I'm sure it's better than nothing.
    Nov 2015
    154
    Set your rad fans to pull into the case and set them to run at high speed should blow a tornado through over your mobo near your M.2slot.
  7. #7
    ROG Guru: Green Belt Array GoNz0- PC Specs
    GoNz0- PC Specs
    Laptop (Model)Dell XPS 9530
    MotherboardRampage V Extreme
    Processor5930
    Memory (part number)[Ripjaws 4] F4-2666C15Q-16GRR
    Graphics Card #1Asus Strix GTX980
    CPU CoolerEk Evo Supremacy
    CaseCorsair 800D
    Power SupplyEnermax 1250w revolution 85
    Keyboard Logitech 710+
    Mouse Razer Mamba 2012
    Headset Sennheiser PC350
    OS Windows 8.1 Pro
    Network RouterAsus AC68u
    Aug 2012
    24
    568
    It has been said that the stickers metallic so conductive enough to slap a heatsink on
  8. #8
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    The poor thermal conductors - stickers, plastics, etc - are already on the device anyhow, securing any kind of heatsink over top will multiply surface area and can only improve thermal performance. Not as good as a properly-engineered thermal interface, perhaps, but better is always better.
    Try installing/moving fans or drives so that there's stronger airflow across the hottest parts?
  9. #9
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme Encore
    Processor10980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2417H
    Storage #1Intel Optane 905P PCIe
    Storage #2Samsung 970 EVO Plus
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    tistou77's Avatar
    Apr 2012
    109
    1,631
    the 950 Pro heats much more than the SM951 NVMe (same controller)
    With the latter, I'm at ~ 42° with Crystal Disk Mark (36 ° in idle)
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme Encore
    CPU: i9 10980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 905P PCIe
    DATA: Samsung 970 EVO Plus
    SOUND: Asus Xonar Phoebus
  10. #10
    OS Windows 10 Pro
    Jan 2014
    79
    I thought about it and ended up using a razor blade to peel the sticker up and then I put it on some random plastic shell that most things come in so I can save it and put it back if I need to return the drive.
    I found an old TO-220 heat sink and was trying to think of a way to hold it to the drive. I thought why not get extreme so I got a small dual bb fan and used a zip tie.
    Now even under massive load the drive never goes over 60C with no other fans on in the case, the little fan whistling away running wide open.
    I wonder if this fan generates any kind of EMF that may be colliding with the ram chips, it's actually almost touching them as you can see in the pics.
    The fan whine is minimal at full speed and if the other fans come on it's not a problem, with no load it's not even running since I put a temp sensor I put under it and manual fan profile I made that is assigned to that temp sensor thanks to Asus!
    Thoughts about the possible EMF? Also it is touching what looks to be a capacitor..
