Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Member Array
    Dec 2015
    5
    Phoebus driver 8.1.1.35 without Sonic Studio Pro?
    Hello!
    Today I formatted my PC and installed as fresh copy of Windows 8.1 x64.
    I went to the Phoebus Driver section, as I always do and downloaded the most recent windows 8.1 x64 driver: the driver version 8.1.1.35
    SURPRISE!!! ...AND WHAT A BAD SURPISE!!!
    Sonic Studio Pro is no longer available in the package!
    So now, I have a crappy sound with that crap of "ROG Xonar phoebus Software"
    Why remove the Sonic Studio Pro from the driver??
    Is there a link where I can download the previous package?
    Will Asus Support team verify this and correct this?
    Say something..
    ROG Member Array
    Dec 2015
    5
    So, if you want the driver with Sonic Studio Pro, the one that was removed from the asus Website,
    It's available here http://www.touslesdrivers.com/php/co...p?v_code=45610
    Why did they removed the driver? Don't know...
    Hope this would help the ones that are lost in this, like I was.
    ROG Guru: White Belt Array oG kill3r PC Specs
    oG kill3r PC Specs
    MotherboardZ390-H
    Processori9 9900k
    Memory (part number)CORSAIR DOMINATOR 3600 32GB
    Graphics Card #1PNY RTX 3080 XLR8
    Sound CardSOUND BLASTER G6
    MonitorASUS XG43VQ
    Storage #1SAMSUNG 970 PRO M2 512GB
    Storage #2SAMSUNG 970 PRO M2 512GB
    CPU CoolerNZXT M22
    CaseNZXT 710i
    Power SupplyCORSAIR HX1000
    Keyboard CORSAIR K65
    Mouse CORSAIR DARK CORE RGB PRO SE
    Headset BEYERDYNAMIC 990 PRO
    OS WINDOWS 10
    oG kill3r's Avatar
    Feb 2012
    107
    Sonic studio was terrible i'm glad its gone !
    ROG Guru: White Belt Array MRBULL PC Specs
    MRBULL PC Specs
    MotherboardMaximus Formula XI
    ProcessorIntel I9 9900k
    Memory (part number)G.Skill F4-3400C14-8GTZ
    Graphics Card #1EVGA GeForce RTX 2080 Ti XC ULTRA
    Sound CardROG Xonar Phoebus
    MonitorROG PG279Q
    Storage #1Evo 970 1TB m2
    Storage #2Evo 970 500gig m2
    CPU CoolerEVGA CLC 280
    CaseObsidian 900D Super Tower
    Power SupplyCorsair HX Series™ HX1050
    Keyboard Logitech G510
    Mouse Logitech G502
    Headset Sennheiser pc350 special edition
    OS Windows 10 pro
    MRBULL's Avatar
    Nov 2013
    28
    84
    lol same here , Rusher u on crack or what ? so much more options and better sound without that crapy ass sonic studio , reason why they took it out ..
    ROG Guru: White Belt Array Florin's Avatar
    Dec 2013
    121
    Actually the Sonic Studio has ENC (noise cancelation) for my Xonar Mic while on the Phoebus standard control i have only Beam forming which is garbage. This is the only reason i keep Sonic Studio Pro installed.
    i7-4790k + Corsair H80i | Asus Maximus VII Ranger | 16 GB Corsair Vengeance DDR3 1866 | Sapphire R9-290 OC Vapor-X 4GB | Asus Xonar Phoebus + Audio Technica M50 | 1xSSD Corsair 120 GB | 4x1 TB Seagate HDD | Corsair CX750M | Corsair Carbide 300R | Razer Taipan + Logitech G11 | Windows 10 64bit
    ROG Guru: Yellow Belt Array Rewerend PC Specs
    Rewerend PC Specs
    MotherboardAsus Crosshair V Formula - Z
    ProcessorAMD FX-9370
    Memory (part number)2 x KHX23C11T3K2/8X
    Graphics Card #1R9 Fury X 4gb Sapphire
    Sound CardAsus Xonar Phoebus
    MonitorSAMSUNG U28E590D 28" uHD + freeSync
    Storage #1Samsung SSD EVO 540 250Gb
    Storage #2Seagate 7200.14 2TB
    CPU CoolerCorsair Hydro H105
    CaseCooler Master Cosmos II
    Power SupplyENERMAX ERV1000EWT-G Revolution87+ 1000W Gold
    Keyboard Microsoft SideWinder X6
    Mouse Saitek MAD CATZ R.A.T. 7
    Headset Asus ROG Orion
    Mouse Pad Steel Series PAD
    Headset/Speakers Genius Home Theather SW 5.1
    OS MS Windows 8.1 Pro
    Network RouterAsus RT-N18U
    Accessory #1 Zalman ZM-MFC3 FAN/TEMP CONTROLLER
    Jun 2014
    12
    126
    ENC works
    Quote Originally Posted by Florin View Post
    That´s not true, If you have connected your headset and if you choose ROG command in headphone tab you will see Enable ENC, so it´s working and for me the voice is also clear.
  7. #7
    Dec 2013
    121
    For me it doesn`t show ENC ...
  8. #8
    oG kill3r PC Specs
    MotherboardZ390-H
    Processori9 9900k
    MonitorASUS XG43VQ
    CPU CoolerNZXT M22
    CaseNZXT 710i
    OS WINDOWS 10
    oG kill3r's Avatar
    Feb 2012
    107
    Looks like ENC to me ?
  9. #9
    Dec 2013
    121
    And this is what i have, i need the Sonic Studio Pro to enable ENC. Lucky for me the new driver does not remove the old software, so i get the best of both worlds.
  10. #10
    ROG Guru: Orange Belt Array
    Oct 2012
    12
    272
    You have to plug your mic into the rog command thingy for enc to work.
Tags for this Thread
