Infernal Lan Overclocking workshop 4/24/10
Retired
Not applicable
Part of the ROG EXPERIENCE TOUR* we stopped by Intel Lanfest Infernal Lan to hold an overclocking workshop! For those of you that just signed up* please submit your screen shots in this thread!
We will be benching on a Maximus III Extreme* Intel 870 CPU* CPU-Z!
Scores must be submitted on HWBOT under the "ASUS REPUBLIC OF GAMERS" team!
The member with the highest CPU-Z Frequency validated and posted here at Infernal LAN will win an Maximus III Formula.
We will be tweaking with ROG Connect!
LETS OVERCLOCK!
15 REPLIES 15
V2-V3
Register account with HWbot at HWbot.org
Join the HWbot team: "ASUS REPUBLIC OF GAMERS"
__________________________________________
Intel LANFEST DUPONT ASUS ROG OC Contest: Day 1
Contest Benchmark: CPUZ 1.54
http://www.cpuid.com/cpuz.php
Goal: Highest CPUz Valid Frequency for the Intel i5-670 on the ASUS Maximus III EXTREME Motherboard
Rules: NO cheating!* must have CPUZ Validation of Speed* Must use ROG connect to achieve overclocks
Validate by submitting your clocks through CPUID
Create New Windows User Account with Administrator privileges
change resolution to 800x600 16bit
Turn off clear type
set windows appearance to best performance
Disable all Startup Commands in "MSCONFIG"
Disable all Non Microsoft or "necessary" Services in "MSCONFIG"
Disable Background set to "None"
Disable Screen Saver set to "None"
Install all HWbot Benchmark Apps
1. CPUZ 1.54
take a Screen shot "Print Screen" of your Clocks* than Validate by submitting your clocks through CPUID
2. Super Pi Mod
set affinity to core 2 (or unused core)
set priority to real time.
when completed Print Screen before clicking "OK" to capture Checksum
Run 1M and 32M
repeat several times for best results.
3. wPrime
Run 32M and 1024M tests
when completed Print Screen before clicking "Submit Scores" in lower right corner
4. SiSoft Sandra
Run "Processor Arithmetic" Benchmark by clicking "Refresh"
take Screen shot of "MIPS" (FPU) score for HWbot submission.
5. PiFast
when completed save Screen Shot
6. AquaMark3
"Can not set Priority or Affinity for AM3"
AQ3 is Single Threaded (Disable extra cores in bios if possible to gain higher overclock)
Select Measurement "AquaMark Score Measurement"
when completed save Screen Shot of GPU/CPU Score
7. 3DMark2001
set affinity to an unused core or Disable any others if possible to gain higher overclock
Run Benckmark
Save Screen Shot Showing Score* CPU and Resolution.
8. 3DMark03
(Single Threaded)
Run Benchmark
9. 3DMark05
(Dual Threaded)
set affinity for 2 cores (Disable any others if possible to gain higher overclock)
Run Benchmark
10. 3DMark06
(Quad Threaded)
Run Benchmark
11. PCMark04
Set Windows for "Best Appearance" and make sure Classic view is not on.
(Dual Threaded)
Run Benchmark
12. PCMark05
(Quad Threaded)
Run Benchmark
Retired
Not applicable
Retired
Not applicable
Retired
Not applicable
Here are my results: http://hwbot.org/community/submission/993440_pancake_cpu_z_core_i7_870_4678.34_mhz?new=true
Thanks fo ASUS for showing up at InfernaLAN. ASUS FTW!!
ottoyu34
Nice submissions! Great job.
You guys are lucky* I wish I could be there to try it out.
Retired
Not applicable
Retired
Not applicable
AnthonyLackey
Retired
Not applicable
