Eleftherios wrote:
I hate to be a bother but did you by chance look at the link I posted? In the first 5 seconds of the video you can see what I can only describe as artifacting but I feel my words are misplaced.
These "artifacts" can caused by heat.... BUT can be caused ALSO by nvidia driver as well as from non patched game...
if you're on stable Nvidia driver... try to update to a later beta driver...
if you're on beta... return to stable release driver...
if you're on latest stable... downgrade to previous stable driver...
as you see - you need to play with that....
Make sure to check "clean install" when you run the nvidia install.
Try also to wipe CLEAN the nvidia driver after you uninstall it and before you install it again -
using DDU.
what are the chances that you'd manually edit some graphics config files - to enhance the view/fps ?
I know that messing with some parameters cam cause odd game graphics behavior.
are you using any mod ? -> can also lead to odd behavior.
also, make sure to run "windows update" - if you're on 8.1 there are numerous updates - but that is a long-shot.
finally, if you can't seems to solve it by software - try to RMA the laptop and complain about heating above the average...try also to request new GPU/CPU pasting OR that the motherboard will be replaced fully.
if you're lucky... they'll be out-of-stock for replacements - and offer you complete new laptop ( g-sync enabled or G752 ?? who knows.....that isn't far fetched... that is how I got my G751JT after my G55VW had a problem and RMAed it )
Asus G751JTSamsung EVO 850 120GB + 1TB HDD 7200RPM
Cleaned installed Win 10 HOME
My Guides:
- [POST=538713]ROG LAPTOPS: COMPLETE DRIVER LIST ![/POST]
- [POST=538713]How to install windows 8/8.1/10 on any UEFI supported laptop the PROPER way[/POST]
- [POST=538711]HOW TO (EASILY!) UPGRADE FROM WIN7 SP1/8.1 WITHOUT GOING THROUGH THE UPGRADE PROCESS ITSELF ![/POST]
- [POST=605307]HOW TO REMAP FN+KEY AND SPECIAL BUTTONS: "STEAM", "ROG" & "SHADOWPLAY"[/POST]
- [POST=539663]Win 10 x64: SETUP USB @SUPERSPEED, NO HANG-UPS! | ACCELERATES USB 3.0/2.0 TRANSFER RATE SPEED TWICE![/POST]
