Results 1 to 5 of 5
    ROG Enthusiast Array
    Jul 2012
    27
    PCI-E Slot Setup Help.
    Hello, I’m looking for some help setting up my RVE PCI-E Slots. I have the following hardware.
    Intel 5960x CPU
    32Gb's Corsair Dominator Platinum CMD16GX4M4A1800C16
    2x Nvidia GTX Titan X
    SoundBlaster ZXR
    Samsung 950 Pro M.2 512gb
    Does this PCI-E configuration look correct?
    Nvidia GTX Titan X PCIE_X16_1
    SoundBlaster ZXR PCIE_X4_1
    Nvidia GTX Titan X PCIE_X16/x8_3
    Samsung 950 Pro M.2
    Any input would be greatly appreciated.
    THX
    ROG Member Array
    Jun 2014
    13
    Nvidia GTX Titan X PCIE_X16_1****
    ROG Guru: Orange Belt Array coyi1895 PC Specs
    coyi1895 PC Specs
    MotherboardAsus Rampage V Extreme BIOS 1502
    Processori7 5930K
    Memory (part number)CMD16GX4M4A2666C16 (single kit)
    Graphics Card #1Gigabyte GeForce GTX 980Ti G1 Gaming
    Graphics Card #2Gigabyte GeForce GTX 980Ti G1 Gaming
    Sound CardAsus Xonar Essence One/Asus Essence STX II
    MonitorAsus ROG Swift PG279Q
    Storage #1Samsung 950 Pro 512GB
    Storage #2Samsung 840 EVO 1TB
    CPU CoolerCorsair H110i GT
    CaseCorsair Obsidian 750D
    Power SupplyCorsair AX1200i
    Keyboard Corsair Vengeance K70 RGB Cherry MX Red Switch
    Mouse Mionix Naos 8200
    Headset Beyerdynamic MMX300
    Headset/Speakers Corsair SP2500 2.1
    OS Windows 10 Pro 64-bit
    Network RouterAsus RT-AC68U
    Accessory #1 Storage #3: ST2000DM001
    coyi1895's Avatar
    Jul 2012
    26
    300
    That's fine. PCIE_X4_1 shares the bandwidth with the 2 USB 3.0 ports next to the LAN port and SATA Express E1. Depending on the cards, X4 will disabled both of the USB 3.0 ports and SATA Express E1. The soundcard will only disabled the SATA Express E1. Just a head up in case you're flummoxed why they're not working.
    Jul 2012
    27
    Ok thanks for the help.
    Merry Christmas
    coyi1895 PC Specs
    Processori7 5930K
    coyi1895's Avatar
    Jul 2012
    26
    300
    No problem. If you need to use the SATA Express E1 you can move the soundcard to the PCIE_X16_4 slot. PCIE_X16_4 is reduced from X8 to X4 if the M.2 slot is populated. In fact, the popularity of M.2 SSD Gen 3.0 is making the PCIE_X16_4 slot a handy place to put the soundcard/add-on cards.
    Merry Christmas
