12-11-2015 07:15 AM - last edited on 03-06-2024 03:03 AM by ROGBot
01-10-2016 02:25 AM
01-12-2016 08:17 AM
Sect wrote:
good to hear you got it to read in the ufei.
Have you monitored it's temperature during use at all?
what BIOS version did you upgrade to to get it to work with default settings?
don't forget to install the NVMe drivers from samsung 😄
01-12-2016 08:58 PM
01-12-2016 11:57 PM
01-13-2016 09:50 AM
Sect wrote:
Install the nvme driver from the samsung website.
The Samsung Magician Software is actually quite light and worth installing. You can test your drives in it, but dont be too concerned with the 950 benchmark as it's not an accurate reflection of its performance.
If i check the SMART info for my 950 I get somewhat alarmingly high temp readings, so I'll have to look into whether it's a correct reading or not.
01-14-2016 10:20 PM
01-21-2016 09:50 PM
