Waskadagama wrote:
If you have problem with GeForce Experience 2.7.4.10, uninstall ASUS GameFirst III.
I had the same problem with my G751JY-DB72, it helps.
After several hours uninstalling and installing different versions of Geforce Experience, changing settings and looking in the internet for a solution, I found that this is the solution to the problem.
How do I get to this point, I did a clean install of windows 10, then installed Geforce Exp. and then one by one piece of software from the Asus drivers website, after each install I opened Geforce Exp. to check compatibility, once I got to the Asus Gamefirst, Geforce did not work anymore, hence,
Uninstall ASUS GameFirst III, (it suppostly prioritize internet banwidth for games, not sure if you need it or not, I don't have heavy internet applications running in the background while I'm gaming).
