12-16-2015 03:23 AM - last edited 3 weeks ago by ROGBot
12-16-2015 03:36 AM
From0toHero wrote:
I made with the windows tool a usb installation and the process showed no issues. But as soon i install the needed drivers and preform a sfc/scannow command it finds problems that not can be fixed. I tryed two diffrent SSDs but with the same result. If i install Windows 8.1 first and than upgrade to Windows 10 that dosent happen. I also used two diffrent USB sticks. But as soon i install anything the sfc/scannow finds issues that cant be fixed.
How comes??
12-16-2015 03:39 AM
12-16-2015 03:51 AM
12-16-2015 04:02 AM
vmanuelgm wrote:
Read the final of the text, there you can find the files corrupted.
12-16-2015 04:32 AM
12-16-2015 04:49 AM
12-16-2015 05:02 AM
12-16-2015 05:57 AM
12-16-2015 06:50 AM
