Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    ROG Enthusiast Array
    Dec 2015
    40
    Q-Fan Control - optimal settings for 4790(K) / 4460and others
    Hi there !
    I´ve put a 4790K into my G20AJ, downclocked to 4Ghz, undervolted ~ -70mV, which seems to be stable.
    (Turbo Boost Short disabled)
    (Intel Extreme Tuning Utility)
    I´ve xperimented a lot with the Q-Fan Control settings in BIOS. Here are my actual values (for both fans):
    20C -- 15%
    55C -- 30%
    70C -- 70%
    As a result fan speed is about 27% in regular working mode, packaging temp somewhere at 50C quiet stable.
    Starting a download meanwhile results in ~ 10-15% CPU Load and leads to ~ 30-35% fan speed on 55-60C, which is acceptable for some time here and there.
    Stress testing leads to stable ~70C at 67-70% fan speed.
    Well, for now it is the best I can find. But I would be interested in your settings especially on the 4790 / K but also any other CPU for the others here. When I got my unit with a 4460 the fan settings had been horrible in comparison.... The last settings I had with the 4460 were:
    30C -- 10%
    55C -- 25%
    70C -- 40%
    That was quiet nice for regular working but I had not finished testing on high cpu load, also not undervolted. Maybe you want to try it out. I finished with the 4460. (btw selling mine, if you are interested, let me know)
    ROG Guru: Yellow Belt Array a100 PC Specs
    a100 PC Specs
    MotherboardH97 Asus
    ProcessorIntel i7-4790 3.6GHZ
    Memory (part number)16GB
    Graphics Card #1Zotac GTX980Ti Reference OC`d GPU: +210MHZ - Memory: +300MHZ
    Sound CardOn board
    MonitorBenQ XL2430T Gaming LED Monitor
    Storage #1Samsung Evo Pro 850 512G SSD
    CPU CoolerRog Dual Fan
    CaseG20AJ
    Keyboard Asus
    Mouse Asus
    OS Win 8.1 Core Single Language
    Accessory #1 Logitech G27 Racing Wheel
    Aug 2015
    11
    146
    Have you felt any performance changes by upgrading to 4790K on G20?
    Dec 2015
    40
    Yes, a lot lot lot. It was worth it 100%, an least for me.
    AC Unity got a very nice boost, the 4460 limited gpu power.
    a100 PC Specs
    MotherboardH97 Asus
    Sound CardOn board
    CaseG20AJ
    Keyboard Asus
    Mouse Asus
    Aug 2015
    11
    146
    Hmm so we can overclock CPU on G20 after all.
    Could you plz write a detailed way of doing it, I have 0 experience in overclocking cpu`s.
    How you did it? which software? and .. tnx
    Dec 2015
    40
    Oh I don´t overclock, just undervolt.
    New ROGer Array
    Oct 2015
    2
    Quote Originally Posted by Paul.Jandali View Post
    Hi there !
    20C -- 15%
    55C -- 30%
    70C -- 70%
    30C -- 10%
    55C -- 25%
    70C -- 40%
    How did you manually does this in the BIOS? I was just in there and didn't see any option, while I did see a FAN section to monitor and below it a couple of other options, none where for selecting different temps and speed as far as I could tell. I have the i5 with the 760 dont know if that makes a difference.
  7. #7
    Dec 2015
    40
    Quote Originally Posted by Gotallofthem View Post
    On top of the monitor tab you will find an option to check optimal fan speeds or something like that.
    Run it and afterwards Q-Fan Control will grant access to those (mentioned) values.
  8. #8
    a100 PC Specs
    MotherboardH97 Asus
    Sound CardOn board
    CaseG20AJ
    Keyboard Asus
    Mouse Asus
    Aug 2015
    11
    146
    Whats that undervolting for? whats the effect?
    Sorry I`m completely lost in CPU tuning.
  9. #9
    Dec 2015
    40
    Easy, it reduces power consumption, temperatures and therefore might help in reducing the fan noises.
  10. #10
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    My approach is to run the fans up a lot more aggressively, 50% at 40C, 75% at 50C, 100% > 60C. My logic is that the faster temps get brought down the smoother the parts will run, most peak loads occur in bursts anyhow, and I don't ever want sustained peak loads to get throttled. Having very quiet and efficient fans helps a lot, lol.
