the wee man wrote:
yeah that's what I was hoping for too rather than that complicated guide, well that's how I see it anyway, I only have a cpu fan and I think either 2 or 3 case fans, I just simply want them to run quiet when the machine is doing nothing much and then they can speed up if the machine is under load, I don't want anything special.
You are able to do that.
You have two options, firstly in the bios (which I would recommend) or secondly using software in Windows (A.I suite)
You basically set a custom fan curve (or there are preset fan curves for silence, performance etc).
So in other words to put it simply you can control how quick the fan spins at certain temperatures, for example once your CPUs hits 50 degrees centigrade, you could have the fans spin at 100% if you were that way inclined, or you could have them at 60%. You can literally control the fan speed at every temperature.
Alternatively you could set the fans so they run at a constant speed. What you need to do is go into the bios, select q fan control, you then select your fan (they're labelled I.e cpu fan, cha fan 1, 2 etc) you then select pwm (if your fan connector is a 4 pin, or dc if your fan connector is 3 pin). You can then experiment with the different fan profiles, or select manual and move the fan curve yourself.
To get into the bios press del when the ROG logo appears, then press f6 to select q fan control.
Lastly with regards to cpu fan step up and step down, as I mentioned the fan curves dictate what speed fans spin at. At certain temperatures however, the cpu temp can change quickly depending on how much load is applied, and then the temp drops down as the load reduces, this then causes the fan speed to go up and down, and can be annoying.
You use the step up and down option to prevent this happening.
Let me give you an example, the fan is set to hit 90% at 50 degrees, and 60% at 30 degrees. Now if you open software, extract a file etc the cpu load increases (and therefore the temp increases) as soon as the load increases the temp to 50 degrees the fan would hit 90% for a few seconds, and then immediately drop down.
However using the step up and down option you could counteract this so the fan speed would stay constant during short loads.
