Results 1 to 10 of 10
    ROG Enthusiast Array mirkoj PC Specs
    mirkoj PC Specs
    MotherboardAsus Rampage V Extreme
    Processor5960X; 5930k; 3930k
    Memory (part number)64GB RAM on each comp
    Graphics Card #1Asus TitanX; EVGA Titan SC; Gainward 970
    Graphics Card #2Asus TitanX; EVGA Titan SC; Gainward 970
    Graphics Card #3Asus TitanX; EVGA Titan SC; Gainward 970
    Graphics Card #4Asus TitanX; EVGA Titan SC; Gainward 970
    Monitor3x Asus PA328q; 3xDell U2713HM
    Storage #1Synology 1813+: 4x1TB WD RE4 in raid10, 4xWD RED 3TB in raid10
    CPU CoolerCorsair H110i; Corsair H110iGT; Corsair H110i
    CaseCorsair 900D; Corsair 770D; Corsair 800D
    Power SupplyCorsair AX1500i; SuperFlower1600; Thermaltake 1500
    Mouse Logitech MX Master
    Headset Astra A50
    Headset/Speakers Logitech Z5500
    OS Win 10
    Network RouterAsus RT-AC5300
    Oct 2014
    29
    4-way Titan X + triple 4K Surround = stuttering issue
    Looking for some help here.
    Running into an really nasty issues with stuttering and I was hoping to see if that is something I can fix with some settings or what...
    Everything is in maximum details, only AA is turned off, makes no sense to use it on 4K screens really.
    It is much less visible on heaven bench but in valley it is really noticeable from time to time.
    https://www.youtube.com/watch?v=INqYAQz_JCY
    https://www.youtube.com/watch?v=5-mMGYybh7s
    Games are ofc completely different thing as most of them especially new titles have no SLI support at all, and any triple 4k gaming is impossible... The Witcher 3, Fallout4 and even tried SOMA last night and it is all unplayable at those resolutions.
    But for start iw ould be happy to solve this nasty tearing at least on these two benchmarks.
    System:
    5960X (asus 8-core gaming OC preset)
    Corsair H110i
    64GB Corsair Dominator Platinum
    4x Asus Titan X (+200MHz core clock OC)
    512GB Samsung 850 pro SSD
    Corsair AX1500i PSU
    Corsair 900D case
    3x Asus PA328q 32" 4k monitors
    nvidia driver 361.43
    Anyone knows a way to at least try and pinpoint what is the problem, why stutter appears.
    Any chance it is due to disk speed loading textures or something, as I noticed also in free cam mode that when I walks forward it is not that visible almost none, but when i start turning around it is horrible. Like loading new textures slowdown?
    I could upgrade to 2 SSDs in raid0 but no point if taht is not the issue, single one right now is good for everything else.
    Any help is appreciated.
    Thanks!
    ROG Guru: Green Belt Array grassy PC Specs
    grassy PC Specs
    Laptop (Model)ASUS
    MotherboardRAMPAGE 4 BLACK/RIG 2 RAMPAGE FORMULA
    Processor3960X/ RIG 2 4820k
    Graphics Card #1ASUS GTX 980 TI STRIX OC
    Graphics Card #2RIG 2 GTX 690 SLI
    Graphics Card #3RIG 2 GTX 690 SLI
    Sound CardAUZENTECH 7.1 XFI DTSMA
    MonitorDELL U3011/RIG 2 VIEWSONIC MONITOR
    Storage #1480GIG/360GIG/250GIG SSD
    Storage #2RIG 2 180GIG SSD
    CPU CoolerHEATKILLER PRO WATERBLOCK/RIG 2 CORSAIR H105
    CaseIN-WIN 909/1 COOLERMASTER WHITE STRYKER CASES/IN-WIN 909
    Power SupplyCORSAIR AX1200/ RIG 2 CORSAIR HX750
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    Mouse Pad RIG 2 STRYK X
    Headset/Speakers RIG 2 TWO B&W COMPUTER SPEAKERS
    OS WIN 10 HOME/RIG 2 WIN 7 PRO
    grassy's Avatar
    May 2012
    65
    612
    I would love to be able to solve this problem for you right now, but unfortunately this is one of the biggest problems with PC's that i know off and always seems to raise its ugly head in some game or other. I have changed settings to this and that and downloaded and uninstalled drivers till it drove me mad and i still have not got to the bottom of this problem and just when you think its solved, it raises its ugly head again.I don't know off anyone and i mean ANYONE who has solved this problem. Plenty off claims mind you but realistically no solution for the masses. This is the very 1 thing i hate about pc's. I am building a custom water cooling system at the moment to see if that will help with stutter as i have tried everything else. The only answer i can come up with at present is that every game is optimized differently. Try setting your system up in a raid config as that is one thing i have not done yet. Your system spec's seem to be an expensive build and its a shame spending all that money for stutter.That is what pee's me off with stutter. Sorry for the rant but i really hate this problem with a passion.I will be keeping an eye on this thread for a solution just as much as you believe me and i hope it gets solved.
    FAME IS A MASK THAT EATS INTO THE FACE
    grassy PC Specs
    Laptop (Model)ASUS
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    grassy's Avatar
    May 2012
    65
    612
    Read this thread if you have not already http://www.tomshardware.com/forum/10...uttering-games
    Mastermind19 Array
    Oct 2015
    117
    Please set only basic startup programs and no background programs
    In Nvidia's Manage 3D settings, set SLI Rendering Mode to Force alternative rendering 1
    Vertical Sync -> on (smooth) or off (if you want high frame rate)
    You have 4 Titan X SLI, you can turn on Vsync and still get decent frame rate.
    I also set VIrtual memory to Custom size and set to 2.5x memory for max and initial size (MB) to 2927 (or Recommended).
    You can also try Adaptive Vsync
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,247
    Please confirm that you've populated the EZ Plug power connector on the motherboard.
    ROG Member Array Zion_One-Eyed PC Specs
    Laptop (Model)ASUS Ultrabook ROG Zephyrus M GU502
    MotherboardASUS ROG Maximus XII Hero
    ProcessorINTEL Core i7-10700K
    Memory (part number)GSKILL Trident Z DDR4 3200MHz 16GB (4X4GB)
    Graphics Card #1ASUS ROG RTX 3080 STRIX OC
    MonitorASUS ROG SWIFT PG329Q + PG279Q
    Storage #1SAMSUNG 970 EVO M.2 1TB
    Storage #2WESTERN DIGITAL Velociraptor 1 TB
    CPU CoolerASUS ROG RIUJYN 360
    CaseASUS ROG STRIX HELIOS
    Power SupplyASUS ROG THOR 1200W
    Keyboard ASUS ROG GK2000 Horus
    Mouse MMO ASUS ROG Spatha - FPS LOGITECH 502
    Headset ASUS ROG Centurion 7.1 - ASUS Strix 7.1 + ROG Throne Qi
    Mouse Pad ASUS ROG Whetstone + ROG Sheath
    Headset/Speakers SAMSUNG HT F9750W 1330W 7.1
    OS MICROSOFT Windows 10 Home 64-bit
    Network RouterASUS ROG Rapture AX 11000
    Accessory #1 LOGITECH G13 Advanced Gameboard
    Accessory #2 ASUS ROG Phone 5
    Accessory #3 ASUS ROG CHARIOT RGB + ROG Spotlight
    Oct 2015
    15
    amazing !!
    i wait for the new nvidia pascal to play in 4k..maybe
    take a look at mine "2.5k"
    https://www.youtube.com/watch?v=DnClhj82xdM
  7. #7
    ROG Enthusiast Array Mhill2029's Avatar
    Jun 2012
    12
    61
    I run 3x Rog Swifts and i had the same issue with games. But i found in my case it was G-Sync surround that was the cause of terrible microstuttering and triple vision effects on textures when turning. Turning G-Sync Off/V-Sync Off made pretty much everything become fluid in surround and GPU usage jumped up to 95%+ on every card. It seems that Nvidia's last 6 driver incarnations all have this problem and i'm now using the latest.
    The Witcher 3 i cannot get to work above 40fps in surround with terribly low gpu usage, only going to single screen and capping the fps to 60 is it fluid. Without a cap, even on a single display it's terrible.
    Regarding Heaven and Valley benchmarks, they always have odd stutter at certain points with 3 or 4 gpu's. It's normal...
    Intel i7-6950X @ Stock for now
    Corsair H105 (Push/Pull)
    Asus Rampage V Extreme X99 (Bios: 3101)
    32GB (4x8GB) Corsair Dominator Platinums @ 3000Mhz
    512GB Samsung 950 Pro M.2
    2x 256GB OCZ Vertex 4 (RAID-0)
    2x EVGA Titan X Superclocks in SLI
    Corsair AX1500i Titanium + Red Sleeved Cables
    2x 27" Asus ROG Swift PG278Q (Surround 7680x1440 @144Hz + GSync)
    Lian Li PC08 Tempered Glass Case
    Logitech Z906 5.1 Surround
  8. #8
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,718
    Triple monitors at WQHD will cap at 60Hz (=60fps) max. It's a hardwired DisplayPort 1.2 signal bandwidth limitation. Swifts can only function at 120Hz/144Hz/165Hz in single-monitor setups. Swifts can even function at 85Hz in dual-monitor setups with the use of nonstandard hacks.
    That being said, you'll seldom dip below the upper cap (60fps) if your GPU(s) can sustain faster rendering than your monitor(s) can display.
    My 2-SLI GTX980 (and dedicated PhysX) setup can easily sustain >50fps on Witcher 3 without stutter. So something is obviously not working correctly in your 4-SLI TitanX systems. It might involve TitanX G-Sync drivers.
  9. #9
    ROG Guru: Orange Belt Array Legolas PC Specs
    Legolas PC Specs
    MotherboardMaximus X Hero Wifi AC
    ProcessorIntel Core i7 8600k oc 5Ghz
    Memory (part number)Samsung DDR4 16GB
    Graphics Card #1ASUS NVIDIA GTX 1080
    MonitorASUS MS246
    Storage #1Samsung MZVPV256
    Storage #2Samsung MZVPV256
    CPU CoolerCorsair H110I v2
    Power SupplyPC 1200W Turbo-Cool 1200
    Keyboard ASUS SK2045
    Nov 2015
    287
    Quote Originally Posted by mirkoj View Post
    System:
    Corsair H110i
    Corsair AX1500i PSU
    Corsair 900D case
    Thanks!
    I hope everything is working for you.
  10. #10
    ROG Guru: Elusive Ronin Array SinisterDev85 PC Specs
    MotherboardMaximus Vi Hero
    ProcessorIntel i7 4790k @ 4.8ghz
    Memory (part number)G.Skill Trident X 16GB F3-2400C10D-16GTX
    Graphics Card #1MSI 970 GTX 4GD5T OC
    Sound CardOnboard
    MonitorSamsung JU6500 UHD TV
    Storage #1Samsung 850 Evo SSD x2
    CPU CoolerThermaltake Water 3.0 360mm
    CaseThermaltake Core V51
    Power SupplyEVGA SuperNova G2 750w
    Keyboard Corsair Vengeance K70
    Mouse Evga Torq 10 carbon
    Mouse Pad Steel Series
    OS Windows 10 Pro 64bit
    Network RouterAsus Rt-AC3100
    SinisterDev85's Avatar
    Sep 2014
    11
    301
    Well, my Rig is nothing compared to yours, but I do know what you mean about the stuttering issue. Is it happening in all games you try to play?
    I saw you mention Fallout 4 and so I figured I'd comment because Ive been playing that game alot. When I first got it, i was having some serious stuttering issues. I am using a 4k monitor, but my 970 ftw can't really handle graphically intensive games at that resolution so I usually play them @1440p instead.
    But, as for Fallout, I followed some optimization guides for tweaking the .ini files for the game and it totally fixed my major stuttering issues! Your processor for example has 8 cores and 16 threads. Fallout 4's .ini is set only to utilize 4 cores and 4 threads by default. You can manually change those values to better utilize your processor's capabilities. My wife's pc has a 4790k in it and when I adjusted the files to use all 8 threads instead of just 4, that alone improved the performance.
    There are mod tools now that can automatically make several of the tweaks.
    I did have some minor microstutter after tweaking the ini files on my Rig too, but that seems to have gone away when upgrading from a 850 pro to the 950 pro M.2 So maybe your SSD is holding your system back, like you were theorizing? It could be worth it to try a RAID setup and see if you get any improvements.
    And yeah, if I spent that kinda money on a Rig, Id be pissed about stuttering issues too!
    I wish I could be of more help, but I have no experience with multi screen gaming, or those beastly Titan X's. Lol.
    Id be happy to find some of those links if you want to at least try to get one game performing more like what you were hoping.
    ASUS ROG Maximus 8 Hero Alpha | Intel i5 6600k @4.7ghz | G. Skill Trident Z 16gb @ 3499mhz | Samsung 950 Pro NVMe 512gb | ASUS Strix GTX 1070 OC | EVGA Supernova G2 1300w | Windows 10 Pro x64
