Results 1 to 4 of 4
    ROG Member Array
    Oct 2013
    23
    Samsung 950 M.2 with G752VT magician not working
    My drive works perfectly but for some reason the samsung magician software is not recognizing the ssd and I cannot install the samsung NVMe driver.
    I've updated all drivers using driver genius but for some reason I get this issue.
    Any ideas?
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,121
    See this thread http://rog.asus.com/forum/showthread...s-How-I-Did-It
    Samsung Magician doesn't always work Macrium Reflect always does here's a link to a video on how its done with MR The video is just for MR you need to insure you have the correct NVMe SSD to start with the thread I link you to is a success story and very good explanation of how it was accomplished.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Member Array
    Oct 2013
    23
    Thanks but I've used this thread for my installation of windows and the pc works perfectly but that's not my issue.
    I just wanted the samsung magician software to work with my new M.2 ssd and that guide mentions nothing about that.
    ROG Guru: Blue Belt Array Gps3dx PC Specs
    Gps3dx PC Specs
    Laptop (Model)Current: G751JT | Retired: G55VW, G51JX
    MotherboardInc M.2 slot
    Storage #1Samsungs EVO 850 128GB
    Storage #21TB HGST Travelstar 7K1000 (HTS721010A9E630)
    CPU CoolerMother Nature & Thermodynamics laws
    Mouse Logitech MX 518
    Headset/Speakers Logitech T6060
    OS Cleaned installed Windows 10 HOME x64
    Accessory #1 Leap Motion
    Feb 2015
    71
    773
    Quote Originally Posted by drummerdimitri View Post
    Any ideas?
    silly to ask...but:
    1. have you installed the latest version from samsung's site ?
    2. have you googled that issue - because it might not be rog laptop dependant - check to see if ppl with other PCs reporting the same issue...
    Plus, you should know that samsung released drivers v4.8 about 1-2 months ago, which are the 1st official driver to support win10.
    also, NVMe is very new tech relative to AHCI... so knowledge is scarce - again, relative.
