Results 11 to 14 of 14
01-10-2016 03:24 PM #11
Menthol PC Specs Motherboard M 10 Apex / XI gene Processor 8700K / 9900K Memory (part number) 2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500 Graphics Card #1 RTX 2080ti / GTX 1060 Sound Card SoundBlaster Ae5 / Onboard Monitor BENQ 32" 4K Storage #1 Intel 900p 480GB/Samsung 960 Pro 1TB Storage #2 Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro CPU Cooler Corsair H150i AIO / H1110i Case Corsair 740 ? Lian Li Air Power Supply Corsair AX 1200i / AX 1200i Keyboard Corsair Mouse ASUS Strix Headset HyperX Cloud Alpha Mouse Pad ASUS Headset/Speakers Logitech Z906 OS 10 X64 Pro Network Router Verizon Fios Accessory #1 Intel Wifi BT pcie card Accessory #2 Red Bull Accessory #3 English Breakfast Tea
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
Yes you should update the bios to the latest version, check to see if all ASUS software has been removed then use CCleaner to clean the registry of any leftover registry entries
Although 1.4 volts won't hurt your CPU as long as your CPU temps are OK, less than 80 degrees under load, it doesn't require that much voltage for default speeds
But if voltage settings are left on Auto the board will usually set voltages a little higher than needed as Auto settings are set to compensate for any and all CPU's some may need more than others
Once you have everything stable then if you want to install AISuite or other ASUS software, Install one program at a time so if there are issues it will be easier to troubleshoot
01-10-2016 04:51 PM #12
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,247
01-10-2016 08:34 PM #13
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 6
Went and updated to 1102 last night from 0214, I will try and update to the most recent BIOS next. I am actually going to do a complete reformat to reset everything back to default, just finished backing up my important files. Thank you Chino and everyone who had replied with assistance, this forum is a great asset to ROG users
01-12-2016 05:39 PM #14
Vinny1001 PC Specs Motherboard Asus Maximus VIII Hero Alpha Processor Intel Skylake 6700k 4.0GHz Memory (part number) G.Skill 2x 8GB DDR4 Graphics Card #1 Asus STRIX 1080 Ti Monitor BenQ XL2411 Storage #1 Samsung 850 Pro, 840 Pro, M.2 840 Evo Storage #2 2x 1TB WD Black CPU Cooler Corsair H60 Case Corsair Carbide 300R Power Supply EVGA 850 Modular Mouse Swiftpoint The Z Headset Logitech G240 Mouse Pad Swiftpoint The Z Mouse Pad Headset/Speakers 5.1 Logitech Surround Z506 OS Windows 10 Pro, version 1703 Network Router Asus RT N66U
- Join Date
- Nov 2015
- Reputation
- 10
- Posts
- 166
