Inside the ROG G20AJ and probably others like it there is the twin fan right above the cpu. It is connected to the heatsink via some black smooth tape. Tape might be thermal and feels like paper.
Can anyone confirm if it is thermal or not and what I can use to replace it with. I am seeing so many options on the web, it is over confusing me right now and I just need some advice. I did the dvd, memory, video card all at same time upgrade and wasn't as nice to the tape as I should have been. Thinking about it I would like to try and make it right. I look forward to anyones suggestions and help. Thanks.
