Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    New ROGer Array
    Dec 2015
    13
    1
    G752VL Speaker Popping Problem
    As of a few days ago, I have been an owner of a G752VL-BHI7N32. For the first couple of days, everything was perfect, and I had no complaints. But as of yesterday, my laptop's speakers have been expressing some odd behavior. The speakers have frequently been making a popping noise, similar to the sound your lips will make when they are closed tightly and you blow air through them, or similar to the pop noise you hear on your headphones when you plug the jack into the port. This seems to happen right before a program will make a sound, or exactly when the sound is made, and it will also occur randomly when nothing is being done whatsoever. I would like to know whether or not other owners of the same laptop have been experiencing something similar. In another thread, an owner of a similar model in the same product line seemed to report a similar problem, but his or hers sounded more severe. The best thing to do would be to exchange this unit for another, but I would like so see whether or not the issue is inevitable.
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    96
    2,562
    is any one else having Audio issues with their G752 ? Please let us know. I'm still waiting for the G752 ive ordered , but the version is still unavailable for sale . {DH78K} not till end of Jan 2016
    ROG Guru: Orange Belt Array
    Mar 2015
    310
    Had 3 g751jy's, every single one of them had the issue you described. These days, I don't even care about the issue anymore, as it only occurs when sound card enters/exits standby mode.
    ROG Enthusiast Array ReeveJ's Avatar
    Feb 2015
    46
    There is a very long thread detailing this issue on the G751 (search for 'G751 noise,' you'll find it). As Corporal said, it's your sound card entering and exiting the standby mode. This issue has sort of been resolved by a new set of drivers, but you have to disable Power Management in the Windows registry. Basically you'll hear a pop the first time you play a sound after booting the system and again as you power it down instead of before and after every sound. You can get these drivers in the thread which I mentioned.
    It is not a hardware issue. Returning the product will not accomplish anything. To prove this, just uninstall the Realtek HD Audio driver and let Windows use the default one. There will be no crackle. Removing the Realtek drivers will eliminate the popping sound, but I personally think the option detailed above is the better one. Keep in mind however that it's a fix for the G751, I can't guarantee anything for the G752 (even if they're basically the same). I also am still on Windows 8.
    New ROGer Array
    Dec 2015
    1
    ı have g752vt dh72.also ıt has speaker popping problem
    toronto699 PC Specs
    Processori7-4770K
    Storage #1118 GB/OS
    Storage #22.72 TB
    CaseG30AB
    OS W 10
    Aug 2014
    96
    2,562
    U would think after a year of the G571 Release , there would be no Audio Issues on either a G751 or the Asus Flag Ship G752. One Other Little issue I have With Asus. The G752 -VY-DH78K {Demo Model} was on Display in the IFA Berlin Trade Show In September 2015 and CES 2015 and again at CES 2016 But Still Unavailable For Sale. Whats Taking so Long. I Had Audio POP on My G30AB Tower it eventually went away , No driver update installed , still use the original G30AB Audio Driver.
    I Use the Audio Driver From The Asus G11-CB Tower On MY Asus G751, with no issues. I had to replace the G751 Motherboard as the Graphic Card Was Faulty I was not going to fix the G751 but could not wait any longer for the
    G752-VY-DH78K , release , ill give away the G751 to someone in need when I buy the G752-DH78K
    UpDate
    G752-VY-DH78K now Available Jan/12/2016
  7. #7
    New ROGer Array
    Mar 2015
    3
    I have been saving to buy a laptop for study but I prefer ROG due to its high-end specs. I am so grateful to receive it from you if you are serious
  8. #8
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    I have not experienced this with the G751 or the G752 just so its out there that this is NOT present in every machine as some would like to present it. Like anything else you have to take it with a grain of salt as complaints always fly faster than compliments. If anything my only perception of shortcomings with the sound in the G752 is that its weak, especially when compared to the G751. If I want to listen to something where it makes a difference Im using either ear buds or a Bose soundlink III BT speaker.
    The G752VY DH78K is available for sale at multiple outlets. Problem is they are flying off the shelves faster than they can be produced.
    http://www.amazon.com/G752VY-DH78K-1.../dp/B01578ZLEY
    http://www.newegg.com/Product/Produc...82E16834232768
    http://www.costco.com/ASUS-ROG-G752V...100227265.html
  9. #9
    toronto699 PC Specs
    Processori7-4770K
    Storage #1118 GB/OS
    Storage #22.72 TB
    CaseG30AB
    OS W 10
    Aug 2014
    96
    2,562
    I have a G751-VY it is Flawless , motherboard was replaced , defective graphic card , one in a million chance of that happening , No Audio Issues or Any Other Issue.
  10. #10
    Feb 2013
    11
    265
    Same here on my G752VT-T7005T
Tags for this Thread
