Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 51
    New ROGer Array
    Sep 2015
    2
    PG279Q Backlight bleed
    Hello,
    so I got the PG279Q in November and was pretty happy with it. But after using it for a while I noticed that on black screens my bottom left corner was slightly more lit than the others. Now I looked at it on a completely black screen with light switched off and you can definitely see some backlight bleed going on. I can live with the amount of bleed I have but I just wanted to ask if this is normal or if ASUS can do better? I'd like to hear your opinions on my BLB and please tell me what you would do when getting a monitor like this.
    Pictures:
    https://www.dropbox.com/s/bxnf9mgiaz...231_065759.jpg (Brightness: 26)
    https://www.dropbox.com/s/bd4xci413i...231_070207.jpg (Brightness: 100)
    ROG Guru: White Belt Array From0toHero PC Specs
    Laptop (Model)Asus G551JK Microsoft Surface Pro 3 i7 512gigs SSD
    MotherboardAsus Rampage V Extreme
    ProcessorIntel 5930k
    Memory (part number)Kingston Predator DDR4 32gigs (@2144mhz)
    Graphics Card #1MSI 980 GTX Ti 6G
    Graphics Card #2Asus 980 GTX Poseidon
    MonitorAsus PG279 ROG / Dell Ultra Sharp
    Storage #12 Samsung 850Pro 500gigs
    Storage #2Samsung 850Pro 1Terra/ Western Digital Red 3 Terra
    CPU CoolerCoolermaster Nepton 240m
    CaseCoolermaster Cosmos II
    Power SupplyBe-Quiet Dark Pro 11 1000Watt
    Keyboard Razer Chroma RGB
    Mouse Razer Ouroboros/ Logitech G602
    Headset Logitech G230
    Mouse Pad Razer Goliathus
    Headset/Speakers Harman Kardon Sabre SB35
    OS Windows 10 Pro
    Network RouterNetgear Nighthawk R7000
    From0toHero's Avatar
    Jun 2015
    82
    I have the same monitor and a little less ips glow. This is no backlightbleed. And almost all panels have it to some degree. Enjoy your screen.
    ROG Member Array Hertz PC Specs
    Hertz PC Specs
    Laptop (Model)MacBook Pro 15" Early 2013
    MotherboardRampage IV Black Edition
    Processori7-4280k
    Memory (part number)2x F3-2400C10Q-16GZH G.SKILL Ripjaws Z Series 16GB (4 x 4GB)
    Graphics Card #1ASUS GTX980 Strix
    Graphics Card #2ASUS GTX980 Strix
    Sound CardCreative Sound Blaster Z
    MonitorASUS PG279Q
    Storage #1Samsung 950 Pro 1TB
    Storage #2Seagate Constellation ES ST32000644NS 2TB 7200
    CPU CoolerNoctua NH-D14
    CaseCoolerMaster HAF-932
    Power SupplyEVGA SuperNova 1000W P2
    Keyboard Razer Tron
    Mouse Razer Tron
    Headset SteelSeries Siberia v2
    Mouse Pad Razer Tron
    OS Windows 10
    Network RouterLinksys EA6400
    Oct 2013
    11
    That is not IPS glow, it is exaggerated by the photo and overexposure but this is clearly a typical backlight bleed.
    I have exchanged lots of PG279Q and haven't seen any without same problem.
    ROG Guru: White Belt Array Kotronas PC Specs
    Kotronas PC Specs
    MotherboardRampage V Extreme
    Processori7 5930k @4.4
    Memory (part number)CMK16GX4M4B3000C15
    Graphics Card #1Asus Strix DC3OC 980 TI (on EK Predator 360 with QDC)
    Graphics Card #2Asus Strix DC3OC 980 TI (on EK Predator 360 with QDC)
    MonitorAsus Swift PG279Q
    Storage #1Samsung NVME 950 pro 512gb
    Storage #2Samsung 840 pro 256gb
    CPU CoolerEK Predator 360 QDC + 2x 980 ti strix waterblocks
    CaseCorsair 750d
    Power SupplyCorsair ax1500i
    Keyboard Corsair k95 RGB
    Mouse Logitech g700s
    Headset Logitech g930
    Mouse Pad Steelseries 9hd
    OS Windows 10 pro
    Network RouterAsus rt-ac68u
    Kotronas's Avatar
    Oct 2013
    15
    105
Name:	2016-01-06 16.35.17.jpg
    This is my pg279 bought 4 days ago, still not decided if I keep it or return it. That is at 80% brightness when I lower it at 26%-40% the blb is not so much noticeable, it looks like it is gone, except 3 spots. First left bottom side and 2 and 3 top right. But it is getting better on the bottom one, I think the energy paper that was there, produced it after removing it, since it is glued on the panel and not on the frame as is the top.
    Ips glow is visible from near and it changes position as you move your head and positioning. After few feet away you see only blb.
    P.S. the blb on my picture is not the real blb as it overproduced from the phone camera. I was checking the photo and I was wondering where those blb spots are, since I can't see anything on top left corner and bottom right has a minimal white hue on the black.
    So big reminder photo isn't same with live blb.
    New pic with 40% brightness and the blb you see on it i cant see it on real life as it is. On daily the IPS glow is the "issue" if you have one with it.
Name:	2016-01-06 23.47.36.jpg
    and here a 23% brightness
Name:	2016-01-06 23.59.12.jpg
    Hertz PC Specs
    Processori7-4280k
    MonitorASUS PG279Q
    Keyboard Razer Tron
    Mouse Razer Tron
    OS Windows 10
    Oct 2013
    11
    Looks much like mine. Getting a different one seems a huge lottery, the choice is yours. Currently it is more like a take it or leave it situation. Maybe further batches will be different, only time will show.
    ROG Enthusiast Array
    Feb 2013
    36
    This is very common in an IPS panel.
    All IPS panels especially when larger in scale will "Always" have IPS glow, this is not a defect, this is normal (you can never get away from IPS glow).
    Although in your case, almost all corners have too much backlight, which you should return for a replacement.
    Ways you can tell if it is IPS glow -
    • Corners will have a slight yellow/blue lit color when in a dark room while viewing a black or dark image.
    • When viewing an image with color in the area of the "glow" you should not be able to see the "glow"
    Ways you can tell if it backlight bleed -
    • Corners will have a white or slight yellow color when in a dark room while viewing a black or dark image.
    • When viewing an image with color in the area of the "glow" you should still see the "glow/bleed" in that corner.
    If you do not like IPS glow (which is normal for an IPS panel) I strongly suggest you return the product and get a TN or VA panel monitor.
    Asus's IPS panel with amazing backlight bleed thanks to the fantastic AU Optronics cheap panel they used (they should have use an LG or Samsung panel)
    A perfect IPS panel as it should look like
  7. #7
    Kotronas PC Specs
    CaseCorsair 750d
    OS Windows 10 pro
    Kotronas's Avatar
    Oct 2013
    15
    105
    Thanks for explaining it as simple as posible. Already asked for a replacement. As I said the glow isn't a issue and the blb on the corners is low not so much noticeable. The problem is the 3 spots where white spots comes through the bezel and the panel, the 2 spots on top right corner are small and not so intense but the left bottom one is noticeable even on colored images/loading screens. You see from middle black bezel and as you go down you see the white light coming through. Hope the next one is better.
    Thanks again
  8. #8
    Feb 2013
    36
    Its funny there is even all these defects, take a TV for example, they are all mostly IPS panels, especially the new TV's with 4k display.
    Further, almost all TV's do not have backlight bleed or IPS glow.
    These IPS TV's also are ranging at 240hz which allow for 120hz per eye when viewing in 3D.
    I also want to add that these 55-60" tv's in 4K with 3D capabilities, 60hz with 120 motion plus, Wifi and network connections, Full HD surround sound speakers, live Firmware updates. Applications such as Internet, Youtube, Vivo, Netflix etc...
    There is even IPS TV's ranging up to 240hz (not at 4k scale) for cheaper costs.
    Only cost $1200+ these days... That in mind, I want everyone to think about this, and I want you to ask yourself.
    Why the heck am I paying $1200 for a 1440p 27" pc monitor with only... 165hz, does not allow for users to update Firmware.
    Does not have a wifi/wired internet connection (which would allow for frequent bug fixes on the fly), Does not include further features within the monitor, Terrible useless speakers.
    Terrible backlight bleed which should not exist, (I've only seen a minor blue glow in most monitors which we call "IPS glow")
    That is with me referring to the 16,000 pc monitors I've deployed to clients.
    Asus, I love you. But I really hate your new monitors... you are better than this... and you aren't being honest to your clients.
  9. #9
    Kotronas PC Specs
    CaseCorsair 750d
    OS Windows 10 pro
    Kotronas's Avatar
    Oct 2013
    15
    105
    Got my replacement today it is much better then the last one.
    Here a pic at 80% brightness
    The spots on the top are not so visible as it is showing on the picture. I saw them as I was trying to take the picture.
    First one was a October this one is November one.
    This is a keeper for me as it is.
  10. #10
    Feb 2013
    36
    Everyone who has any Backlight bleed or IPS glow to the extent the corners are showing visible light should be returning their Monitor for a new, or RMA.
    Monitors should only have a slight blue glow around the edges which is present on most TN, IPS panels.
    Which when viewed in a dark lit room and a black wallpaper is mainly when you are able to see this.
    If you experience any yellow or white "glow" or "light bleed", this is not normal for any monitor, this is a defect in the build quality.
    Please RMA until you receive a proper monitor without these defects.
Tags for this Thread
