Results 1 to 9 of 9
    ROG Member Array
    Feb 2013
    14
    Cool Cleaning outside and inside of the G751-JT
    Since we've now had our laptops for quite some time, we're all probably seeing some grease buildup, dust, etc, between the keys on the keyboard. Has anyone come up with a nice was to make this laptop look 'like-new'? I've been using compressed air, and occassionally a damp rag, but I want to make sure I don't matte certain sections of the computer. Any advice?
    Cheers,
    B
    ROG Guru: Orange Belt Array navis995's Avatar
    Oct 2014
    50
    320
    Isopropyl alcohol and microfibre cloth will do the job.
    Asus Rog G750JZ
    Screen: 1920x1080 17.3'
    CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
    GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
    RAM: Samsung 32GB 1600MHz
    Storage #1: Samsung Evo 840 250GB
    Storage #2: Samsung Evo 850 500GB
    Storage #3: Seagate Barracuda 2TB
    Storage #4: Samsung Evo 128GB MicroSD
    ROG Member Array
    Feb 2013
    14
    The alcohol doesn't dry out the rubber-like material too much?
    ROG Guru: Green Belt Array
    Jun 2015
    17
    612
    Quote Originally Posted by Homerjsimpso View Post
    Long term use of alcohol will dry out and make the rubber coating peel (yes i have seen it on 3 g751s already) not to mention it leeches plasticizers out of the plastic which can lead to cracking and brittleness. Think car dash in the sun. Just use Distilled water and a microfiber cloth.
    3d printed parts and accessories for the G751. You know you want something better than OEM ->https://www.shapeways.com/shops/aeolisio
    ROG Enthusiast Array
    Jan 2012
    36
    I am dreading the day I have to open mine up to clean the fans, heatsinks and repaste. It looks like so much work.
    Oct 2014
    50
    320
    Quote Originally Posted by Sniffy View Post
    That's because it is. My G750JZ takes 3h to be cleaned completely and have it's thermal compounds reapplied.
    Asus Rog G750JZ
  7. #7
    Oct 2014
    50
    320
    Quote Originally Posted by aeolisio View Post
    That is interesting, I did not know that. Then again I do not believe I have any rubber like material on my G750JZ.
    Asus Rog G750JZ
  8. #8
    Jun 2015
    17
    612
    20 mins tops you need a screwdriver and a credit card for prying up the keyboard. You dont need to disconnect anything under the keyboard just lift it enough to blow and wipe the fans.
  9. #9
    Jan 2012
    36
    Hmm I will try that. Are you sure you can lift it up enough to give them a good enough clean? Eventually I'll have to open it all up to repaste but I wouldn't mind doing smaller cleans every now and then if its possible.
