Hello,
I bought a PG279Q yesterday, and I can't set it to 144Hz. I only can go up to 120Hz, on normal, gsync, or ULMB mode.
I'm using the latest 361.43 nvidia drivers, and the latest monitor driver, connected to a GTX670 SLI on a W10 pc.
I can't create a custom resolution too, I don't know why!
I know that with this graphic card can't go up to 165Hz, but why not 144hz? It stuck ever at 120Hz. I don't know why, if my graphic card is 144Hz capable and the monitor too.
I have too a terrible flickering (screen is turning black for a few ms all the time) when running CS:GO on the PG279Q at fullscreen, and have any window open in the secondary monitor. It only happens when I have enabled GSYNC in global config, and ULMB enabled on CS:GO config (NVCP). If I disable GSYNC, it works OK, and if I disable ULMB on CSGO, it works OK too. How can I solve it?
Thanks in advance!
