Results 1 to 9 of 9
    ROG Member Array tonka-tommy PC Specs
    Laptop (Model)ASUS ROG G73SW
    MotherboardASUS Rampage V Extreme U3.1
    ProcessorIntel i7-5630K Unlocked LGA2011-3
    Memory (part number)G.SKILL Trident Z Series 64GB DDR4 2800Mhz
    Graphics Card #1ASUS Strix GTX 980ti OC
    Graphics Card #2ASUS Strix GTX 980ti OC
    Monitor1x ASUS PG279Q 27" 165Hz & 3x ASUS 24" 1080
    Storage #1EVO 960 Pro 512GB M.2
    Storage #2EVO 950 Pro 1TB, EVO 950 Pro 512GB x2
    CPU CoolerCustom EKWB Water Cooled System
    CaseCorsair 780T Black
    Power SupplyEVGA Supernova 1000W
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G900
    Headset Astro A50 Gen 3
    OS Windows 10 Pro 64bit
    Dec 2015
    8
    Fan control when using Linux?
    I have the mentioned motherboard.
    Running Windows 10 Pro 64bit.
    I would like to use a different fan controlling software other than Fan Xpert 3.
    Downloaded SpeedFan, but it can't see any of the fans connected to the motherboard.
    HWMonitor also can't see any of the fans connected to the motherboard.
    When I'm using Linux Mint 17.3.
    lm_sensors can't see any of the fans either.
    As well as a lot of other sensors etc.
    Is this to do with the circuitry ASUS have created or am I just missing something?
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,247
    Other than SpeedFan, I don't know of any alternatives to Fan Xpert III. Why not control them via the BIOS?
    ROG Enthusiast Array sl@sh PC Specs
    sl@sh PC Specs
    MotherboardAsus MAXIMUS VIII RANGER ATX LGA1151 Motherboard
    ProcessorIntel Core i7-6700K 4.0GHz Quad-Core Processor
    Memory (part number)Kingston HyperX Fury Black 16GB (4 x 4GB) DDR4-2666 Memory
    Graphics Card #1Asus GeForce GTX 980 4GB STRIX Video Card
    MonitorBenQ XL2430T 144Hz 24.0" Monitor
    Storage #1Samsung 950 PRO 512GB M.2-2280 Solid State Drive
    Storage #2Seagate 4TB 3.5" 5900RPM Hybrid Internal Hard Drive
    CPU CoolerCorsair H90 94.0 CFM Liquid CPU Cooler
    CaseCorsair 780T ATX Full Tower Case
    Power SupplyCorsair RM 1000W 80+ Gold Certified Fully-Modular ATX Power Supply
    OS Microsoft Windows 7 Professional SP1 OEM (64-bit)
    Dec 2015
    29
    I see you have a corsair 780 T. Did you connect the fan power cables to the connectors coming from the front panel, or to the fan connectors on the motherboard?
    Mouse Logitech G900
    Dec 2015
    8
    Quote Originally Posted by Chino View Post
    Hey Chino, yea I may just have to.. It's just nice to have control without having to go to bios each time.
    Quote Originally Posted by sl@sh View Post
    Hey sl@sh, Straight to the motherboard, I haven't used the fan controller that comes with the case. I might just give it a go and see what it's like.
    I still have the issue with not being able to see the connections through the OS. Is this a common problem?
    Oct 2012
    339
    15,247
    Quote Originally Posted by tonka-tommy View Post
    Make sure you buy PWM fans and you can control them by temperature. I set mines and just leave them alone.
    sl@sh PC Specs
    Dec 2015
    29
    @tonka: I am using the case connectors. But that means the motherboard is not connected to them at all, and therefore the BIOS can't see them. I only connected the water pump and CPU fan to the appropriate pins on the mobo. Those I see, both in BIOS and in cpu-z. But not the others.
    I never tried, but I would expect that the BIOS recognizes fans connected to the mobo. I take it you do see them in BIOS?
  7. #7
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    Personally I use the bios to manage my fans both CPU and case fans, ASUS bios is very good at this, once you set them to your liking it's done, I don't like installing software that is not needed, in my experience these programs can cause conflicts and issues that are difficult to troubleshoot
    Simplicity is Bliss
  8. #8
    Mouse Logitech G900
    Dec 2015
    8
    Yea I can see all the fans in the BIOS, but I can't see them using SpeedFan or HWMonitor or using Linux at all.
    Seems strange that only the AI Suite 3 can see them. Unless ASUS has done this on purpose??
  9. #9
    ROG Guru: Orange Belt Array
    Aug 2015
    35
    442
    Quote Originally Posted by Menthol View Post
    Simplicity is Bliss
    98% agreed, I prefer to have the BIOS control things, but the 2% is that I do like to be able to check it in the OS which is where linux is problematic.
    tonka-tommy, to incompletely answer your question and share your frustration - I doubt anyone is trying to hide anything, but rather linux needs to be made aware of how/where/what it needs to talk to get this information and control these things. Even if you know its on an i2c bus for instance, you still need to know what registers are there and how they work to control/view it (hence my question about lm_sensors, I am too lazy to figure it out myself if someone already has).
    Much like the corsair USB situation - its just a dumb device on the USB bus. In fact, people have reverse engineered its register space, but over the years standards and consistency have been hard to come by unless some killer app/feature/competitor forces the issue, so they scatter such things around as hardware needs dictate and then assume they will pretty it up in software.
Tags for this Thread
