Please help me find Fresh Window 10 drivers for G75VW
code9523
Hello!
Please help me find fresh drivers for my g75VW.
I'm going to update to windows 10 home but I cant find drivers on support page.
Please help!
Asus G74SX> Asus G55VW 3D> Asus G75VW 3D> Asus G750JW> Asus G750JX> Asus G750JH
GottiBoi55
code9523 wrote:
Hello!
Please help!
Hi code9523.
When you run the Windows 10 upgrade, Microsoft will search, and download an install the best latest drivers for your G75VW.
Microsoft will run compatibility tests on your hardware and install the best drivers for all your hardware.
Since Windows 10 preview first came out, Microsoft been working on issues from feedback from users.
For instance, on my G750JZ at first the Intel HD 4600 graphics was not compatible with Windows 10.
But come time for the Windows 10 roll out in July, that issue was fixed.
(Most all my drivers installed by Microsoft are not older then July 2015)
When the Windows 10 upgrade starts just make sure you click on "check for updates recommended" for best results.
If something is not compatible, Microsoft will give you a list of each issue.
Then all you need to do is visit the vendors website and search for there drivers there.
Hope this sheds some light on this subject for you?
Good luck, and good gaming!
PS: I just went back to 8.1, at the moment 8.1 performance is better for me.
I will also wait for some bug fixes, had some issues with system file corruption with the latest build update from Microsoft update that was just pushed out in November.
Here's a link on what bug fixes Microsoft is working on >>>>>Microsoft working to get next Windows 10 Build Redstone
GottiBoi55
Asus
G750JZ-DS71 Windows 10 Pro (x64)
Intel® Core™ i7 4700HQ (2.40GHz)
Samsung
24GB Memory DDR3 1600 MHz SDRAM
SanDisk
M.2 SSD 2x128GB in Raid 0 / WD-HGST-1TB HDD 7500-RPM
NVIDIA® GeForce® GTX 880M 4 GB GDDR5 VRAM
Second Monitor: Shar
p Aquos 32"
