Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    ROG Guru: Yellow Belt Array
    Sep 2015
    11
    246
    Aida 64 will pass, RealBench will not pass
    So, after getting a rock solid overclock on the 4300 hz range on minimal voltages I pumped up a little and tried the 4500 hz range.
    With pretty acceptable voltages still, the machine would pass 10 hours aida 64 stress. I was happy with this until I tried RealBench - RealBench would fail within the first 15 min where Aida would hold 10 hours with same settings. But still while gaming (nothing heavy though) the system would not fail in any way.
    So, what should I think about this? Trust aida results or suspect tehm taking in consideration the RealBench result?
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    RealBench is tougher on your system than AIDA64 and may require more voltage and more voltage means higher temperatures or better cooling, it is your system and whatever works for you is what you should be concerned about, stress tests and benchmarks are great tools for testing your system and comparing your system to others, but as long as it is stable doing everything you do, starts every time, resume from sleep, etc. than it's stable for you
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    498
    13,504
    Aida 64
    Realbench
    ROG Guru: Green Belt Array Dr. Zchivago PC Specs
    Laptop (Model)Lenovo Thinkpad T410
    MotherboardASUS Crosshair V Formula - Z
    ProcessorAMD FX 9590
    Memory (part number)BLE2KIT8G3D1869DE1TX0 (8-8-8-24, 1866 MHz)
    Graphics Card #1ASUS R9 390 STRIX (OC, GAMING)
    Storage #1SG Constellation 6 TB (6x1 TB) RAID 0
    Storage #2SG Constellation 2 TB (2x2 TB) RAID 1
    CPU CoolerNoctua NH-D15
    CaseCaseLabs STH-10
    Power SupplyCorsair AX1500i
    Keyboard Microsoft Sidewinder X4
    Mouse Microsoft Sidewinder X5
    Headset Logitech G930
    Mouse Pad Perixx 900x440x3 mm + Steelseries 320x270x3 mm + ALLSOP hard pad
    Headset/Speakers Logitech G930/Altec Lansing 5.1
    OS Windows 8.1 Pro (64 bit)
    Dr. Zchivago's Avatar
    Oct 2013
    66
    609
    Quote Originally Posted by Arne Saknussemm View Post
    Aida 64
    Realbench
    OCCT
    Z
    Resistance is futile (at <1 Ohm).
    Sep 2015
    11
    246
    Very self explanatory
    Now I got another problem - where AIDA and REALBENCH passed, OCCT will fail within the first five minutes, damn it Just tried it...
    Back to the voltages
    ROG Guru: Green Belt Array Qwinn PC Specs
    Qwinn PC Specs
    MotherboardRampage V Extreme - BIOS 3301
    Processor5930K @ 4.4 GHz Adaptive 1.27v / 4.2 Ghz cache Offset +0.27v / Input 1.92v / LLC7
    Memory (part number)G.Skill 32gb DDR4-2666Mhz 15-15-15-35-CR2 1.2v at XMP settings
    Graphics Card #1Gigabyte Gaming G1 980Ti OC to 1455Mhz Core 8000Mhz memory at Stock Voltage
    Graphics Card #2Gigabyte Gaming G1 980Ti SLI
    MonitorROG Swift PG278Q
    Storage #1Intel 750 PCIe 1.2TB
    Storage #2Sandisk Ultra II 960GB SSD
    CPU CoolerThermaltake Water 3.0 Ultimate (360" rad AIO)
    CaseThermalTake v71 Full Tower
    Power SupplyEVGA SuperNOVA 1200 P2
    Keyboard Saitek Eclipse II
    Mouse Razer A5090 Master of Destiny
    OS Windows 10 Professional 64 bit Build 10586
    Jul 2015
    46
    670
    Yep, I ran for months on a 4.5Ghz OC that I thought was perfectly stable, until I ran OCCT within 10 minutes and it failed (consistently). My current 4.4Ghz OC can run OCCT for 8 hours without a problem.
    It is worth it though. When I thought my 4.5Ghz was perfectly stable, I would still - very rarely - get issues booting or a rare freeze when alt-tabbing between programs. It was rare enough that I was willing to blame software conflicts or "just a fluke". But the current 4.4 OC doesn't have any of these issues.
  7. #7
    Sep 2015
    11
    246
    I have a problem with OCCT - it does not report correct temps, the program sensor inflates them, readings are way to high, I can confirm it if running diferent temp reader side by side...
  8. #8
    Qwinn PC Specs
    Jul 2015
    46
    670
    My OCCT temps are consistent with temps in HwInfo64.
  9. #9
    Sep 2015
    11
    246
    Must be something I dont know how to fix, all temp mon progs are fine except for OCCT, much higher temps then real... It will report 80-90 while my temps are 60-70
  10. #10
